Patriotswrath
- Aug 29, 2011
- 25
- 12
@Steev (anyone) - Can your rooted image file be installed using the tablet's internal system recovery ?
It would be nice if there was an alternative option to apply the root for someone who doesnt have access to a PC, but can get to the tablets System recovery utility.
Problems With W7 64Bit and LiveSuiteThank you Steev for you perseverance to help us cheap arse Coby users and ReeDeer for orchestrating this symphony of misfits (me especially). My question, has anyone rooted their 7042 using W7 64bit? I am still a woosey and am holding out doing the root. Keep up the great work guys, we really appreciate all your efforts, even if we are afraid to try them![]()
Make sure to set permissions 644 on the xml files!
nimsu said:... anyone figure out a fix for the sdcard issue?
If you ever get around to asking a specific / detailed question, perhaps someone will assist you.Thanks guys. Using patriot's steps got google play. sd card is still an issue
Oh.. I thought it was a known issue.
The SD card does not get recognized when trying to view it with builtin apps like aldiko or es file explorer. It seems to label the internal memory as "SD Card"
1) akido sees it fine, go into files then press the up buttonThanks Pats and Red Deer... Seems odd that they renamed the sd card.
1)Have you found a way to get Akidbo to see it? (Not a giant issue)
2)Getting flash to work
3)A Barcode Scanner that works.
