[ROM] Blue Water - Kyros MID 8027 - MPMAN 827 - Mediox MID8027
Other question Insanewolf,
Just in case I'd like to put original rom, I don't understand what does it mean on .txt file 'please use the T-card if you want to update the FW.'
means SD card and the same installation procedure as bluewater?
Insanewolf,
Can I change 'goodfix' file from original rom to bluewater file and install again, screen will run??
Hi, I have been suffering from the screen not working since upgrading to bluewater - thing is I have got this working, I have done that much I can put my finger on what the fix was. Thing is if some can advise me what files to pull of my working touch screen I can share. I have a Coby Kyros 8027 (capacitve
I have the same problem. I'm restoring firmware. I would appreciate your help!!!
Should I install these files adding the bluewater files? Or just installing YOUR files?
EDIT: I copied the files to the original "BlueWater" folder and then flashed. Still with same problem.
Ok, I'll try those files! Could you tell me which things did you do to fix it? I mean... Did you use ClockWorkMod Recovery? Because I don't know what else I should do! And thanks a lot, I really appreciate your efforts! :)
I've flashed it three times with your zip and the problem is still here... Don't know what to do... Thanks to everybody!
nice work InsaneWolf :D I just got me a coby kryos mid 8027, and wanted to put bluewater on it :) everything went fine, and it works, I only have one problem, it shuts down often, but very randomly, is there anybody who know how to fix it ? :) thx.
