Hi at all, i have big problem.
I have the Dikom 8000, that people said is the same of Coby 8127, and I brick it because I have flash Bluewaters 1.0 that is a rom for 8027.
The tablet is ok, it turn on correctly but touchscreen is brick, i don't unlock android first page.
The strange is that soft keys are ok, it turn on when i touch them.
Have You some trick for me? Have You original rom or custom rom for my tablet?
Please help me :°
Many thanks Insanewolf, I have try many times to upgrade with FWDN but always I get a not found rom at boot.
I follow instructions withous get results. I push Volume+ and Powerup together but to upgrade from sdcard i haven't problem but with tablet connect in usb and FWDN i doesn't.
Bluewater seems that is ok, only problem is touchscreen.
Have you another rom to suggest me that I may update from sdcard with touchscreen drivers corrects?
Thanks![]()
It's possible to you make a test firmware for us?
For example, FWDN itsn't ok for me, but ics update is released. It's possible to transform firmware update for ics in a update from sdcard like bluewater?![]()
