Read and re-read the dev sticky like it says... then remember to rename cw_recovery to cwm_ recovery and place in the right folder. also if you have at least intermitent wifi, check your router for a firmware update.
ro.wifi.channels=
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=IML74K
ro.build.display.id=20120515.122329
ro.build.version.incremental=20120515
ro.build.version.sdk=15
ro.build.version.codename=REL
ro.build.version.release=4.0.3
ro.build.date=Tue May 15 12:23:45 CST 2012
ro.build.date.utc=1337055825
ro.build.type=user
ro.build.user=yuzhou
ro.build.host=androidSRV
ro.build.tags=release-keys
ro.product.model=MID1042
ro.product.brand=coby
ro.product.name=crane_MID1042_SC3099
ro.product.device=crane-MID1042-SC3099
ro.product.board=crane
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=unknown
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=exDroid
# ro.build.product is obsolete; use ro.product.device
ro.build.product=crane-MID1042-SC3099
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=crane_MID1042_SC3099-user 4.0.3 IML74K 20120515 release-keys
ro.build.fingerprint=coby/crane_MID1042_SC3099/crane-MID1042-SC3099:4.0.3/IML74K/20120515:user/release-keys
ro.build.characteristics=tablet
# end build properties
# ADDITIONAL_BUILD_PROPERTIES
ro.com.android.dateformat=MM-dd-yyyy
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.notification_sound=pixiedust.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
dalvik.vm.heapstartsize=5m
dalvik.vm.heapgrowthlimit=48m
dalvik.vm.heapsize=256m
ro.kernel.android.checkjni=0
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
debug.egl.hw=1
ro.display.switch=1
ro.opengles.version=131072
persist.sys.strictmode.visual=0
persist.sys.strictmode.disable=1
hwui.render_dirty_regions=false
ro.hw.maxbrightness=216
persist.sys.timezone=America/New_York
persist.sys.language=en
persist.sys.country=US
persist.sys.usb.config=mass_storage
ro.ui.fullscreen=false
ro.product.firmware=4.0.3
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
I was able to side load FXR. It couldn't fix the wifi for me, so I boxed the thing up and am sending it back to Amazon for a replacement. When this one comes, I'll make sure to make a backup of my system before I do anything.
I realize I screwed a ton of people over on this rom and I appologize. I no longer own the device but if someone owns the device with screwed up wifi due to my rom then I want to try and see if i can try to fix the issue(do not get your hopes up though). Starting off with a logcat from someone with the screwed up wifi problem. You could try turning wifi on / off while gathering it... also someone with broken wifi and someone with nonbroken wifi, I need the output of blkid from in adb shell.
[ 03-30 08:42:33.359 381:0x2c9 V/MediaScanner ]
pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@4185f2f0
/pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@4185f2f0
[ 03-30 08:42:33.359 381:0x2c9 D/MediaScannerService ]
done scanning volume external
[ 03-30 08:42:58.619 142:0x49a E/WifiHW ]
begin to insmod /system/vendor/modules/bcm40181_dhd.ko firmware_path=/system/ven
dor/modules/bcm40181_fw.bin nvram_path=/system/vendor/modules/bcm40181_nvram.txt
firmware!
[ 03-30 08:42:58.649 986:0x3da E/BluetoothAdapter ]
this device does not have Bluetooth support
[ 03-30 08:43:06.539 142:0x49a D/WifiHW ]
insmod okay,try_time(0)
[ 03-30 08:43:06.539 83:0x74 D/WifiHW ]
Enter: wifi_get_fw_path function, fw_type=0,
[ 03-30 08:43:06.549 142:0xde E/WifiStateMachine ]
Failed to reload STA firmware java.lang.IllegalStateException: Error communicati
ng to native daemon
[ 03-30 08:43:06.549 83:0x74 D/CommandListener ]
Setting iface cfg
Trying to bring down wlan0
broadcast flag ignored
multicast flag ignored
[ 03-30 08:43:06.549 83:0x74 E/CommandListener ]
Failed to open /proc/sys/net/ipv6/conf/wlan0/use_tempaddr: No such file or direc
tory
[ 03-30 08:43:06.549 142:0xde D/NetworkManagementService ]
rsp <213 00:90:4c:11:22:33 0.0.0.0 0 [down broadcast multicast]>
flags <[down broadcast multicast]>
[ 03-30 08:43:06.559 142:0xde E/WifiStateMachine ]
Unable to change interface settings: java.lang.IllegalStateException: Unable to
communicate with native daemon to set ipv6privacyextensions - com.android.server
.NativeDaemonConnectorException: Cmd {interface ipv6privacyextensions wlan0 enab
le} failed with code 400 : {Failed to set ipv6 privacy extensions (No such file
or directory)}
[ 03-30 08:43:06.579 1189:0x4a5 I/wpa_supplicant ]
rfkill: Cannot open RFKILL control device
[ 03-30 08:43:07.599 1189:0x4a5 E/wpa_supplicant ]
Could not set interface wlan0 flags: Operation not permitted
WEXT: Could not set interface 'wlan0' UP
wlan0: Failed to initialize driver interface
[ 03-30 08:43:17.579 142:0x4a6 E/WifiHW ]
Supplicant not running, cannot connect
[ 03-30 08:43:18.589 142:0x4a6 E/WifiHW ]
[ 03-30 08:43:19.589 142:0x4a6 E/WifiHW ]
[ 03-30 08:43:20.579 142:0x4a6 E/WifiHW ]
[ 03-30 08:43:21.579 142:0x4a6 E/WifiHW ]
[ 03-30 08:43:21.589 142:0xde E/WifiStateMachine ]
Failed to setup control channel, restart supplicant
[ 03-30 08:43:26.589 83:0x74 D/WifiHW ]
[ 03-30 08:43:26.589 142:0xde E/WifiStateMachine ]
ng to native daemon
[ 03-30 08:43:26.589 142:0xde D/NetworkManagementService ]
[ 03-30 08:43:26.599 83:0x74 D/CommandListener ]
Setting iface cfg
[ 03-30 08:43:26.599 83:0x74 E/CommandListener ]
tory
[ 03-30 08:43:26.599 142:0xde E/WifiStateMachine ]
or directory)}
[ 03-30 08:43:26.599 142:0xde D/NetworkManagementService ]
[ 03-30 08:43:26.629 1191:0x4a7 I/wpa_supplicant ]
[ 03-30 08:43:27.649 1191:0x4a7 E/wpa_supplicant ]
