Jots's ROM works except for those which are not expected to work. I went back to Joenilan's a2sd Froyo to check on hw specs. Besides I could not get apps from google play under Jota's and headset is not recognized by voip apps that I use unless I re-insert headset 2 or 3 times. I am quite happy with Joenilan's Froyo Fusion a2sd wih 1GB Ext3 partition on internal SD and moved dalvik also to internal SD to leave me with nearly 156 or 157 MB of memory for apps after deleting Huawei keyboard app loaded with the ROM.
On Jota's ROM I set the screen density to 160 to avoid lcd screen density issues for apps but it did not resolve it. I am not sure if the following has anything to do with it which is missing in Jota's ROM in build.prop:
ro.com.google.clientidbase=android-huawei
ro.com.google.clientidbase.ms=android-huawei
ro.com.google.clientidbase.yt=android-huawei
ro.com.google.clientidbase.am=android-huawei
ro.com.google.clientidbase.gmm=android-huawei
ro.com.google.clientidbase.vs=android-huawei
and
ro.com.google.gmsversion=2.2_r9
The above I found on build.prop on Froyo Fusion.
Any suggestions, mods to get apps from play store instead of incomaptibility issues welcome. Thanks.
can u send me that smaller recovery.img?I've installed CWM v6.0.1.2 on my S7-105 successfully.
I just replaced that /res/images/stitch.png with a smaller size (5.64 KB) file then repack img.
when i try to flash CM10 system.img i get an error cause the file is too big... how did u guys handle this?!?I can not the goggle play store work, I click the icon and nothing happens, I have to do, to the google play store work?
Dear Jota and friends
This is my contribution as user to help anothers running this beautiful rom
About CM9
First off all I had changed memory from 160mb to 1Gb with Partition Wizard MiniTool and Link2Sd, please see how do this in XDA Forum, I dont remember link, from who understand portuguese, there is this link with instructions
Tutorial – Como usar o Link2SD / Aumente o espaço livre na memória interna de seu Android | Eu Sou Android
I solved issues with apps that you can not install from Google Play and/or not running in this Rom and suggest made as me
1 - Backup all apps before made upgrade from 2.1 or 2.2 versions, this will be saved in a folder /backups or something else
I use App Backup & Restore that is free, download it in Google Play
https://play.google.com/store/apps/details?id=mobi.infolife.appbackup
2 - Install CM9 and Googleapps with instructions of Jota ( recovery, fastboot, etc etc)
3 - Reinstall again App Backup & Restore and restore all apps you had in your tablet
All runs very well, Adobe Flash Player, SKYPE, YOUTUBE, GPS, NAVIGATION APS, ETC, you can upgrade that from Google Play, there are not conflict now.
Only issue I have is with Netflix, old version runs but dont show image, only sound and legends and new version from Google Play doesnt runs, any idea how solve this please?
If you want , you can download mine from Dropbox, there are 55 apps, use that you want or need, ask me link PM
About CM10
I installed this Rom and need your help please
In my screen there is a circle, and to open something, as app, folder, etc, I need use two fingers, one to put circle, for example, above the app and with another circle to give Enter, I dont have idea how solve this problem, used 120, 160 and 180 DPIS and there is always same problem, can anybody help me please?
I prefer to wait for the final CM10 stable code, because in JB (Android 4.1) you can enable the tablet mode without having to mess with Lcd density, and that is a great advantage.
I plan to do a release of CM10 next week, with all the fixes included, if you want to wait...![]()
Xvon said:Is there any way to make the button size of navigation bar of CM10 to be like CM9?
CM9 (Lcd density is 128)
CM10 (Lcd density is 120, smallestwidthdp=768 or 720, and forcetabletui=1)
YouTube app can't play HD format like 2.2.2 in CM9/CM10, will it be fixed? Thanks.
Hi, thanks for the report!
Did you try to install the apks manually? for some apps that worked for me.
I try to find info about what that build.prop lines does, but not much help.
I wish the posts by individuals carry an s after S7 to identify if it has been tested working on Slim and simple S7 for the FAT.
Youtube app cant play HD because there are no HW decode drivers for S7(slim or fat) beyond froyo..so in CM9 and CM10 astruel has make it to do with CPY ..S7 cpy can handle 360P and 480P but cant 720P(HW drivers could play 720p mp4 smaler then 2500kbs which was just enough for youtube)..with out HW decoder library drivers by hyawai witch are closed source its imposibile to fix..so if you ask me always buy a sony or Nexus tablet or phone ..they are only one who put source for librarys on the internet..other want give you like its top secret..they dont give you updated software and even want give you f...library source for crapy camera and crapy decoder..so only way to punish them is to never ever buy their product again.
Xvon said:Thanks for explaining the HW decoder for S7. Is it only used for S7(FAT/SLIM) or other some devices also by Huawei? Any chance to use HW decoder from other devices by Huawei on S7?
