[ROM] CyanogenMod 9 for S7-105 (testing)
Ola Jota
Great!
I will put a link to your post on the first page, to help others
Tip: my CM9 system.img does include Titanium Backup, you can also use it to backup/restore your apps...
Of course, but we need to made backup before install your rom, right? So I suggested that app or Titanium that is good also
Are you sure Flash work on web pages, with video streaming?
I installed flash app to ICS, can send it to you if you wish
Some sites works anothers no
Youtube works, Netflix no
And Skype, both video and audio work?
Didnt tested, only runs and dont crash, not bad to begin
S7_105/6 needs a file for the touch display, called cypress120-i2c-touchscreen.idc
once that file is in place, the touch works ok
(my cm9 rom includes that file, asturel cm10 does not include)
I plan to do a release of CM10 next week, with all the fixes included, if you want to wait...
Yes I prefer CM10, JB is more soft as ICS and CM9 is good but crashs, tablet turns off alone...
I have JB in HTC One X and is very good, so if we can have this rom stable in Ideos S7 will be great!
Abraço
It has same specifications of model 105, difference is band of UMTs as you can see below
HUAWEI Ideos Tablet S7 Product Description
He instalado cm9 + gapp y al arrancar pide password. hecho wiper con cwm antiguo y con el nuevo. Alguien puede ayudar
I have installed cm9 + gapp and on having started he asks password. for fact wiper with cwm ancient and with the new one. Someone can help
Hi,
My first post here.
I have the same problem of Cansat.
I installed the new CWM and flashed CM9 rom.
When I boot up the same message appears: Type your password
Can we help us ?
I don't have any sd card inserted.
Thx
Enviado desde mi HTC Desire HD usando Tapatalk 2
Hi,
My first post here.
Can we help us ?
Thx
Make a full clean... (clean userdata, clean calvik cache, clean cache... clean everything)
goodoane! could you please build that for me including my "improved" touchscreen drivers for testings?!? i sent it to you on a private message!
Thank you so much
I wipe cache, dalvik cache and data through recovery ....same problem
Then I wipe the same through fastboot but... same problem
I don't know what else to do.
When I wipe data through recovery I read a message like this:
E: format_volume make_extf4fs failed on /dev/block/mmcblk0p2
Es un error comun en esta compilacion si te pide contraseña apagalo y vuelve a encenderlo si sigue iwal tendras prueva en el recovery entrar en advanced y fix permisons y si no entra a formatear y formatea parte por parte
On rebooting when the boot animation dims press power on button more than once. When I press once it still shows up screen asking for password. Try if this helps.
Thanks,
I try it later because yesterday I restore a Froyo backup.
Not working
Type your password appears again
I wipe cache, dalvik cache and userdata through fastboot and "Type your password" one more time
I paste the log:
C:\Android\android-sdk\platform-tools>fastboot erase cache
erasing 'cache'...
OKAY [ 0.217s]
finished. total time: 0.218s
C:\Android\android-sdk\platform-tools>fastboot erase dalvik
erasing 'dalvik'...
FAILED (remote: unknown partition name)
finished. total time: 0.005s
C:\Android\android-sdk\platform-tools>fastboot erase userdata
erasing 'userdata'...
OKAY [ 1.045s]
finished. total time: 1.046s
I think my problem is dalvik because this message appears when I wipe in recovery mode (ver.6.0.1.2)
E: format_volume: make_extf4s failed on /dev/block/mmcblk0p2
I tried installing CWM 2.5.1.8 after this and same message for me "Type your password" :(
I want to taste Ice Cream Sandwich... I hate Frozen yoghurt!!! :cool:
Con que programa se hace el metodo 2
With that program makes to itself 2 the method
