asturel said:cm-10-20120909-EXPERIMENTAL-s7-asturel.zip (not tested)
-- enabled hw vsync
-- maybe sensors are working.. (backported ics's old sensor hal support, but maybe it isnt working..)
if someone tries it plz feedback
p.s. accidently left 'hwui.disable_vsync=true' in build.prop .. please remove that line
Can you tell me why 2.8 gb internal is not visible..do you have problems with it or something else.Basicly that rotation and mobile network and it will have same functionality like CM9.
