co0led said:how to edit build.prop??? i'm a nab
Its something you can find with 30 seconds of googling ,use some file explorer that can edit system files ..I use x-plore
10x wifi can not be used, because the /system/etc/wifi folder the less rtecdc-bcm4329.bin.You need to find a usable put here.This post may be in front of this package.
yes i know, because before i used the wifi hack from belarus forum and work but now, when i install your boot.img to make work the touchscreen on my s7 105 wifi not work, i try replacing again the files from belarus but not work, any idea?? you have wifi working?
I think is possible with the right blobs from your tablet. No reason to not work. But now everythink is just for testing is an alfa stage.Are there any way to create CDMA version (201c) from this rom?
Sent from my Nexus S 4G using Tapatalk 2
tlmax said:hi,
In CM10 Bluetooth is working? Camera? If you can built a ROM with these two it will be a cool ROM that never can imagined.. It will be a Complete ROM.. but thank for your effort.. If you can please reconsider about my words.. but this is a great work man.. thank you again..
hkicsi said:Hi,
I have cross checked the mobile net. Now: I have a sim without lock, this is working in my tablet and in my notebook. I have a sim with pin lock. This working in my notebook - can I give in the PIN, but not in my tablet - not asking the PIN. How to force restart, or reach the screen where can I put in the PIN?
asturel said:im trying to overclock the gpu freqs, (if zte blade is familiar for anyone -- it also has overclocked 2d), unfortunately my isp (upc) decided not to work.. so i have to use usb tethering, and i cant test it, may it will be fixed today..
