i guess i have to rebuild the cm9 (its builded with broadcom bt instead of qcom..)
if u talking about cm9 then its because the != 240 density, cm9 doesn't support other densities, anyway cm9 is frozen, so it possible wont be fixed . (u can change the density back to 240 with e.g. lcd density modder , i think if u change the widget buttons at 240 density it will be ok on 160 too)i want to report a bug.
setting system notification, i want toadd some toggle buttun but the added never show.
cm-10-20120914 feels much faster 4 me, anyone can confirm it?
Me (and others) will be very glad to help and test if there is a version for the s7-105...
did you abandon compiling for the s7_10x ??
He didnt compile for 10x models i think... other people is porting it
asturel said:cm-10-20120914 feels much faster 4 me, anyone can confirm it?
lzzmn said:i want to report a bug.
asturel said:hmm.. tethering works w/ setprop sys.usb.config mass_storage,rndis,adb
so ...
yeah missed something when backporting sensors..
home button is works me at default settings (160 dpi, no tablet things..) with what settings doesnt work?
p.s.: it wanst me, there was a bunch of commit to qcom display for older devices (github had issues in the last few days so i wasnt able to sync)
