I am on 160 dpi and no tablet ui..i try to wipe and install again and same..it act as pageup when on some tekst other 2 buttons work normaly..now its so much faster..i notice and when typing now..there was little lag before.
ah found it,
/system/usr/keylayout/Generic.kl
change
'key 102 MOVE_HOME'
to
'key 102 HOME'
p.s. uploaded fixed version too
guys... noone is paying attention to the other topics so i'll ask here... i'm having a problem installing recovery diferent then the one i currently have (2.5.1.8)...
it allways gives me:
"writting 'recovery'...
FAILED <remote: flash write failure>"
i'm trying to fastboot flash recovery recovery.img
after i try to flash the new recovery i get stuck in fastboot and i can only flash back the older recovery version...
First what version is your tablet and what is your android version?..
Then you can have an answear.
L.E.
I see that you have an 105 fat with capacitve screen. I think that your partition are a little different.Tell us what is the mount output list if you type mount in terminal.
asturel said:
ah found it,
change
'key 102 MOVE_HOME'
to
'key 102 HOME'
Ok work now and that and rotation..for usb t. I will try to play to see why for me not w
i never formated my internal memory so that might be the problem...
when you tell me to do mount in terminal.. you mean -> "adb shell" and then type "mount"?
what am i looking for?
edit: currently on android 2.2
mount
rootfs / rootfs ro,relatime 0 0
tmpfs /dev tmpfs rw,relatime,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
/dev/block/mtdblock4 /tmpdata yaffs2 rw,nosuid,nodev,relatime 0 0
/dev/block/mtdblock2 /system yaffs2 ro,relatime 0 0
/dev/block/mtdblock4 /data yaffs2 rw,nosuid,nodev,relatime 0 0
tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0
/dev/block/mtdblock3 /cache yaffs2 rw,nosuid,nodev,relatime 0 0
/dev/block/vold/179:1 /mnt/sdcard vfat rw,dirsync,nosuid,nodev,noexec,relatime,u
id=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset
=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
/dev/block/vold/179:1 /mnt/secure/asec vfat rw,dirsync,nosuid,nodev,noexec,relat
ime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,ioch
arset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
tmpfs /mnt/sdcard/.android_secure tmpfs ro,relatime,size=0k,mode=000 0 0
And if you go to 120 dpi (tablet ui) is it then also fast?
oh well.. i quit... i cant figure out why i cant flash this...
try to use the recovery.img of ere
wipe everything and flash the ROM..
use boot_cm10_104_105.img of goodoane upon flashing the latest cm10
hope it help you out..
if the wifi wont work. use the wifi fix of belarus forum by angelsgroup
@goodoane.. i just figured out that there's a storage problem after shutting down the device.. it will reset everything and go back to 160mb internal phone storage from my 2nd ext-partition 2.5GB..
having this problem from "cm-10-20120912-EXPERIMENTAL-s7-asturel" to the latest one
with ur bootcm10.5.2.img and boot_cm10_104_105.img
i thought reflashing solved the problem..
thats the recovery i'm trying to install... but i allways get that error...
i have internal memory of 106Mb, internal SD Card of 8Gb, android 2.2, older recovery installed (the only one that fastboot allows me to install)
i failed also in fastboot command before..
the way i use to install recov is using trizet's_v3.zip..
open the "upgrade" file and select the option "reinstalling clockworkmod"
but first u must rename the recovery.img of ere to "recovery-trzmod3.img"
and replace "recovery-trzmod3" v2.5.1.8 that goodoane ported.
Hi how about the phone calling?
After installing it's saying "To make a call first turn airplane mode off".
And the SIMCARD PIN box don't show.
Changing to 120dpi want get you tablet ui in cm10..insted of that you change parameter forcetabletui=0 or 1/2 or 1 in build.prop and is also very fast bit is wierd so i stick with normal ui.
Just turn off simcard pin password in settings securitu or in any other mobile phone.
That is the eaisyest way for noobs..just replace files in that install for trzmod with one for S7 and click install.
