luisrene88
- Sep 1, 2012
- 28
- 4
good work i-m waiting cm9 rom for my ideos s7 fat (105) somebody can show a video runing cm9 on your s7 slim please?
i flash it on my s7 slim successfully..
I just wanna know how can I use my touchscreen normally instead of sth like pointer?
adb remount rw
adb shell
cp /system/usr/idc/t1320.idc /system/usr/idc/msm_touchscreen.idc
cp /system/usr/idc/t1320.idc /system/usr/idc/mxt224.idc
reboot
i can't see msm_touchscreen.idc or mxt224.idc in the file.that's because the screen isnt calibrated (.idc missing) i had T1320, but u can try to copy /system/usr/idc/t1320.idc to msm_touchscreen.idc or mxt224.idc
First thank you very much for this rom..i lost hope that I will see anything besides froyo on this device.
Rom works very good for alpha..
And now what I would like to fix
There is no option for use only 3G in setting like it was in froyo(there is only for force 2g)..so device almost always connect to 2g instead of 3g which makes it unusable..I have sim card with unlimited data plan and can't find way to force it to 3g.
Second you could make status bar thicker ..its oversized and to fat so using to much screen space.
There is no way to see recent apps ..its not maped to any off 3 buttons..if you can map it for long pressing home button..
There is more stuff but I now that you also now them but I would like to thank you again for your work.
asturel said:there is no option in cm9 for wcdma settings, dunno why.
navigation bar height - ok
few days ago the long home/power button worked, i did not change anything, may someone broke it in cm9 (?) :S
OK I find the weird way to force 3g only
On phone type *#*#4636#*#*
Select phone information and chose wcdma only.
It should be set with notification widget in n.drawer but since that can't be shown(always display same.. wifi,bth,GPS and sound no matter what I change in option)..is that also not working for you or just me.
I am using your last version..did not try first..maybe long home button worked in first but you broke in last you upload.I see that you add tablet UI in changes but changing dpi to tablet dip like 128 crashes system UI.
I dont care about camera so don't bother with that because every phone has better but hope in some future version you will fix tehtering.Thank again..
Edit..I found the way whow to edit togles in notification drawer in status bar with some external app.
I flashed first and second version on S7 Slim 201u from Poland and it works. What bugs did you encounter?I tried, i failed on my s7 slim 201u, it seems that this rom is for s7, not slim.
ICS PROBABLY can be flashed through CWM v.2.5.1.8 but version from Asturel is newer and works better. You can't flash ICS through official Huawei recovery.can I install this without cwm? how?
I also encounter the same problem, when installing from cwm it said the rom for s7, so that it failed to install to my s7 slim.I flashed first and second version on S7 Slim 201u from Poland and it works. What bugs did you encounter?
PerGert said:I flashed first and second version on S7 Slim 201u from Poland and it works. What bugs did you encounter?
As i sad you need that recovery from astorel flashed first..you cant flash ics with old recovery.wheeqo said:I also encounter the same problem, when installing from cwm it said the rom for s7, so that it failed to install to my s7 slim.
and what do you mean, with "first and second version"?
wheeqo said:can I install this without cwm? how?
