This project is wonderful ! this tablet was dying, i hope you could finish it.
The dropbox link is dead, somebody can fix it please ?
you cant flash try that old recovery ics...you need that from asturel..just copy it to somewhere on pc ..enter that directory via cmd and flash with command "fastboot recovery recovery.img"
So that's how to do it, sorry noob hehe. It should placed in 1st page. Correction the command should be 'fastboot flash recovery recovery.img' isn't it?
Update: WiFi broken on my 201c (CDMA) using 09/02 version
Sent from my Nexus S 4G using Tapatalk 2
I try to compile s7 kernel is a failure, the phone can not enter the system 。automatically restart twice backward recovery , or fastboot automatically when the recovery damaged.I use an older version of config, there may be a problem? !No knowledge really terrible
may u made the boot.img with wrong base addr,
btw.: i dont rememby exactly, but i had 'no boot' problem when used 'wrong' arm eabi gcc, the cm9's one is ok. (4.4.3)
bootimg --repack-bootimg 0x20000000 console="ttyMSM2,115200n8 androidboot.hardware=qsd8k_s7" 2048 2048
running: mkbootimg --kernel /tmp/targetfiles-NNQZXD/BOOT/kernel --cmdline console=ttyMSM2,115200n8 androidboot.hardware=s7 --base 0x20000000 --pagesize 2048 --ramdisk /tmp/tmpyCSQZC --output /tmp/tmpWLxKQD
but u could enable cm9's inline kernel build feature:
just remove the comment from #TARGET_KERNEL_CONFIG := config (and make sure the config file is available at Huawei_S7_kernel_2.6.32/arch/arm/configs)
then mka bootimage
ps.: dont forget to put the kernel into kernel/huawei/s7/
btw..: since the init.device.rc file is: 'init.s7.rc' androidboot.hardware should be s7
Another great update :D
I have a minor issue with a new splash image. I'll try to make it clear: before loading a bootanim something weird is going with a splash image - it became greenish and two copies of it are appearing on top of display. Maybe you should remove a splash image and add a original bootanimation instead? I've uploaded original ideos bootanim on my dropbox: https://dl.dropbox.com/u/24315589/bootanimation.zip
I am from china i have a question, 101 can use this rom?
My english is very bad...so,maybe you can't understand .....sorry...
