is it normal that first boot takes more then 10minutes??? :S
edit: more then 20 now... still loading
edit2: 35minutes maybe..... still loading.... is this normal?!?!?
Not anymore.
Opened from video streaming websites there are occasional can play but only a few minutes earlier, after it suddenly stopped and the browser screen video so it hangs, but strangely why the sound of a live broadcast is still continuing there out?
I cant help you more....i instaled that flash apk..use dolphin beta and flesh work normal..i use 2 flash for live stream
at least you can put it to workall of my browsers work with flash ad's but flash videos will not work in the browsers. Dont know what should i do again, im stuck off and stress about it.
Which post... i try to find ... sorry bad englishi already gave u a link with step by step tutorial... check last page
this is the EASIEST way -> http://www.androidtablets.net/forum...87-jellybean-ice-cream-sandwich-ideos-s7.htmlWhich post... i try to find ... sorry bad english
co0led said:this is the EASIEST way -> http://www.androidtablets.net/forum/huawei-ideos-s7-technical/46287-jellybean-ice-cream-sandwich-ideos-s7.html
this is an alternative way > http://www.androidtablets.net/forum/huawei-ideos-s7-technical/46180-rom-cyanogenmod-9-s7-105-testing.html
if you dont manage to install it.. i can try to help you step by step tomorrow... where are you from? maybe i know how to speak your language
right now i reflashed my tablet with 2.1 :> loool... i dont know if this deleted old recovery... when i try to get into recovery nothing happens...
but still gives me the error when i try to install the recomended one for cm9/10... flash write failure
