(Sorry if this is OT, but someone in this thread asked for it)
I found the way to replace splashscreen on S7 slim from hungarian forum, you can use it to change geeksu image on startup:
Multiupload.nl - upload your files to multiple file hosting sites!
You just go into a fastboot mode and run logo.bat
logo.img.1 and logo.img.2 are different files that i tested on my device, you just have to remove the digits after extension.
There is also a script to make your own logo, but I didn't test it and I don't know if wrong image would brick a device, so try only if you know what are you doing!
I tried to test CM10 today, but I couldn't get tablet ui to work, changing build.prop as written on page 23 caused some weird acting of UI (no status bar and whole screen was moved slightly to the left with a black bar on the right part of the screen) so back to CM9 now.
