kalya said:how can I know if this is functional ?
taki01 said:Is paranoid android working with cm9?
Paranoid android how do you change dpi?
WiFi dosen't work.
Anyone know how to get Play Store fully working? I cannot download simple apps like for example Drag Racing... The same on both CMs. Even Gmail app isn't shown.
Thanks Asturel, your CM 10 is quite goods and now works on my ideos slim 201u , but i have got little question when using google text to speech engine is always comes up with error "google text to speech stop" , how to fix it ?...thanks
asturel said:
Hello relax, do not be moody and sulky. Try reading page 44 posts @ Timeline and page 47 posts @ kefir1992. If yours S7 Slim, could definitely have a new face ICS or JB, view similar to Huawei MediaPad official. And as asturel said DONT FORGET TO WIPE ! NO WIPE NO SHINE ! Good luck!![]()
I installed paranoid ..and works very good..on first boot it gives boot loop but after restarting boots normally ..I had a problem setting APN (always would get off the screen) but in the end it worked..everything else works for what I see.
LBJWDEBSH said:ei mate does the camera is working now mate??
