hey? why this recovery don't work on my ideos s7 slim? the asturel recovery that i have does not finish loading and restart the tablet....
i'll give a chance to paranoid android.. if everything goes fine build in 2-3 hours..
p.s.: i guess i try it later.. they merged some changes from cyanogenmod but did not updated the necessary branch ... and i tried of fixing one-by-one
I had same problem. Install original ROM first. Then after second boot, enable ADB. Then restart tablet to fastboot mode and flash recovery (fastboot flash recovery recovery.img) and boot tablet normally. Next step is to reboot tablet to recovery by ADB - You should search for that, don't try keys combinations, or You will be doing it all over from start. You should be in the Asturel's recovery now.
Think I helped, had the same problem.
some reason the wpa_supplicant.conf isnt autocopied anymore.. and i didnt checked it, sorry, but its easy to fix: Goo.im Downloads - Browsing wifi
superuser: its a common bug in cm10, will be fixed in the next few days (i think)
Hi Asturel, wifi works now. How about bt?
The bug i reported before is not very accurate, in fact, it should be this:
If you turn on bt, turn off bt, then turn on bt, this time it keeps say turning bt on;
And if you try to turn on wifi, wifi cannot be turned on. It seems bt blocked wifi.
While If I just trun on and off wifi, no problem.
yeah no one answering.....so i just say.....yeaah only in dpi 120 the tablet ui working......lame and too small
<img src="http://www.androidtablets.net/forum/attachment.php?attachmentid=8225"/>
<img src="http://www.androidtablets.net/forum/attachment.php?attachmentid=8226"/>
Wait for paraniod rom..you will have any tablet mode u want ..untill then use normal mode.
after first boot I close my tablet and when I restarted it start . now it's OK
paraniod options from settings not function
What's new in paranoid ROM does it fix the camera
And also I was browsing play store I saw cm10themes when I try to apply it its error
Are there compatible cm10 themes in our s7 slim
Congratulations! You've successfully compiled ParanoidAndroid for your device!
-> Next & last step, is to find an Existing PA ROM for a device with similar Screen Density as your device.
-> Drag & drop ParanoidPreferences.apk from Existing ROM to <Your-ROM ZIP>/system/apps/
-> That's it. You're done! You can test your build by flashing the output zip via CWM.
i missed the last part of the pa compliing..
Never minde .
I'm back to your version from 24 sept
