Rotation now work but now phablet mode want work with this version..system ui force closes when truing to open notification bar..also i dont like this 2.18 ..they remove almost all togles..there is just wifi ,bluetooth and airplane mode(why they did that?)asturel said:pa_s7-2.18-08OCT2012-142912.zip probably fixed the sensor (didnt tested it but should work)
p.s. bootanimation changes didnt applied, sorry
removed, need to fix the ril
unfortunately i cant (or it least i dont know how to sync 'back')Rotation now work but now phablet mode want work with this version..system ui force closes when truing to open notification bar..also i dont like this 2.18 ..they remove almost all togles..there is just wifi ,bluetooth and airplane mode(why they did that?)
Can you compile and 2.16 version with rotation fix.
asturel said:unfortunately i cant (or it least i dont know how to sync 'back')
i noticed that too (system ui FC)
u can replace the libsensorservice.so from the 2.18 and the sensors will be ok
LBJWDEBSH said:just instaled the latest paranoid..
one quesion
when im openning the about tablet in settings it just force close it said unfortunately settings has stopped.. whats the problem there..
and also is the phablet mode now working in the latest version??
and when im swipping up the notifications it dosent show up
thanks
lzzmn said:Hi asturel,
What's the corresponding gapp for this version?
I used this one, gapps-jb-20120815-KonstaKANG.zip, but if finished, reboot will failed.
Ok here is file with paranoid rom with all paranoid settings work,rotation fix ,boot animation replaced ,with new adreno drivers ,gapps included and apex launxher
If you have paranoid or cm10 flash with out wipinig anuthing
Zippyshare.com - pa_s7-2.16-01OCT2012-225810.zip
lzzmn said:Great.
Thanks.
