silvamichael said:Guys, if you are encountering proplems with Themes in Paranoid, resize "Theme Chooser" and "Themes Providers" to 120dpi in ParanoidAndroid Settings then reapply the problematic theme afterwards![]()
asturel said:cm-10-20121010-EXPERIMENTAL-s7-asturel.zip 4.1.2![]()
Ok here is file with paranoid rom with all paranoid settings work,rotation fix ,boot animation replaced ,with new adreno drivers ,gapps included and apex launxher
If you have paranoid or cm10 flash with out wipinig anuthing
http://www17.zippyshare.com/v/38088368/file.html
could anybody just upload it to another host? i cannot download it anyway. thanks again!
many thanks again !
pa_s7-2.18-10OCT2012-182400.zip bunch of change, 4.1.2, maybe they fixed the systemui bug too
I upload file to 2shared, if you still have problem say to what host you want to upload:
pa_s7-2.16-01OCT2012-225810.zip download - 2shared
Edit: When you open the page you need to click on second Download button.
beenhow said:in the latest version,when you dail,auto rotation doesn't work well. it is horizontal screen when you dail, but when you are phoning, the screen is always vertical even though i set the auto rotation. only in some previous versions, the phoning screen can perfectly change with the rotation setting.sorry for my bad English. hope you can fix it. thanks anyway !
Goo.im Downloads - Downloading twrp_touch_recovery.img twrp touch recovery
p.s.: probably it works fine w/ goo manager
i didnt tested it, i was just curious how does it looks/works so it can have bugs
It does not have anything with asturel ..its dial app that way ..download ultimate rotation control and set to "force auto" and every app will rotate or you can set different settings for every app.
