asturel said:
hmm could u post a logcat? (i dont have sim in my tablet anymore..)
I thing is this
11-18 12:46:14.032 D/ConnectivityService(315): resetConnections(wlan0, 3)
11-18 12:46:16.382 D/ConnectivityService(315): ConnectivityChange for mobile: CONNECTED/CONNECTED
11-18 12:46:16.402 E/ConnectivityService(315): no dns provided for mobile - using 8.8.8.8
11-18 12:46:16.472 E/ConnectivityService(315): exception setting default dns interface: java.lang.IllegalArgumentException: command '666 resolver setifdns null' failed with '500 666 Wrong number of arguments to resolver setifdns'
11-18 12:46:17.142 E/NetdConnector(315): NDC Command {667 bandwidth setiquota null 9223372036854775807} took too long (580ms)
And there is tons of wpasupplican errors
I thing is this
could u paste @ pastebin.com the whole log? btw i dont think thats related to linaro
You mean hall log in a file..well apn is set right ..it works on normal cm10 and paranoid,maybe is best to insert some sim card and try.And that lib for hw fixed hw decoding in linaro.There is a litle performance increase ..i got 250 more points in antutu benchmark and feeels much more responsive in multitasking.
It same problem to me. In both of cm10 s7-linaro, can't connected to mobile data, all apn setting it same with that i use in latest cm10 and paranoid. Hw 720p it's ok after push additional decoding file. I can't see what's different features between cm10 s7-linaro with another latest cm10 asturel. For me latest paranoid it's best beautiful until right now i'm using, but unfortunately where ParanoidPreferences.apk file? I have had to copy the files from the previous version paranoid in the folder System / Apps /, because I do not find it in the last version paranoid. Cheers..:rolleyes:
asturel said:
applied Gerrit Code Review on the latest paranoid release (it speeds up the ui effects dramatically), please report if ur experiencing wierd ui issues
2.99 is andoird 4.2 and is alpha version and paranoid since 2.99 is not based on CM10 anymore then on AOSP ..is then any change it that new CM10 linaro you posted
asturel said:
where did u get this? just check the build.prop
PLATFORM_VERSION=4.1.2
ro.build.display.id=pa_s7-userdebug 4.1.2 JZO54K eng.android.20121120.022922 test-keys
they still based on cm10 https://github.com/ParanoidAndroid https://github.com/ParanoidAndroid/android/blob/jellybean/default.xml
I have nexus 7 and 2.99 is android 4.2.. and they left CM ..that is why is such huge jump in version number ..but it is still alpha because it dont have yet tablet UI because google trow it out completely so they need time to insert it ..now it not just simple as enabling..but when they do it will be 3.0 version.
I did not install it jet on nexus 7..i am waiting for bugs free..now that multiuser is making a lot of complication and i dont need that option at all..
I thouth that its the same for all 2.99 paranoid versions.
Is there anu way you cam fix sim data on linaro ..its faster by 15% in benchmarks but its more visible in real using ..much less lag so i would like to use that.
i dont think so until i dont get full logcat.
all application run fine so i dont know what can be, and i cant investigate without sim or logcat.
Woow .. pa_s7-2.99-20NOV2012-022923.zip very fast and smooth, it's still jellybean 4.1.2. But sometimes the UI will be hang or display so weird, especially if you frequently rotate the screen and immediately press the settings or notifications or applications. There are some times hangs on lockscreen when the screen rotates. I wonder why the bootanimation at any paranoid version is never good as in cm10? I had to edit the rom, copy bootanimation.zip from cm10 and compile back into a Zip file, then I flash rom. All of These Things I do from a tablet using root explorer, Including the flash recovery and reply to forum discussions now I do from here, because i am lazy to open the laptop during leisure time. For cm10 and paranoid, there are some applications that have been installed are not compatible in a play store. for example, Boat Browser and Twitter could not be updated due to incompatibilities of play store. How to get back compatible as in CM9? I really like Boat Browser Because I think it is best suited for flash player version 11.1.115.12 or 11.1.115.20 for now. Let's help to keep trying for the best rom. Cheers .... :cool:
I've tried some rom
cm-10-20121108-EXPERIMENTAL-s7-asturel.zip faster then official's rom 2.2.2
cm-10-20121119-EXPERIMENTAL-s7-asturel.zip smooth but the status bar always die
pa_s7-2.99-20NOV2012-022923.zip same as 2012119 . I like the paranoid android
Now I just downloading cm-10-20121123-EXPERIMENTAL-s7-asturel.zip at 10 k/s
Hi all,
first of all, thanks for all your hard work to bring us the latest android to this device. ^^
Until yesterday, I used the CM10 ROMs, but i switched to the latest paranoid release. It's cool, but I have encountered a few bugs (maybe they are paranoid related, but I post it here first if it's no problem). First: in tablet UI, the the notifiction bar sometimes just "froze". I can bring up the notifications area, but notifications doesn't change on the bar, the clock doesn't update, etc. It's very annoying, especially when I just take a quick peek on my tablet if I got any new notifications, and I see that the notification area just "froze". If I change the settings for the Navigation bar (software buttons for example), then it's all good again, but it's really frustrating. My other problem is this: I customised the lock screen slider shortcuts, but they don't work either. Not a big deal, but have any of you encountered this (or the other bug)? By the way, I did a data partition reset when installing this ROM, because it was very instable after switching directly from the CM10 ROM, so this is a clean install. Thank you in advance.
could someone try on a linaro build with adding this to build.prop?
Code:
net.dns1=8.8.8.8
net.dns2=8.8.4.4
net.ppp0.dns1=8.8.8.8
net.ppp0.dns2=8.8.4.4
net.rmnet0.dns1=8.8.8.8
net.rmnet0.dns2=8.8.4.4
mobiledata.interfaces=ppp0,gannet0,rmnet0,rmnet1,rmnet2
Hi all,
mee too , I meet the same problem
