asturel said:Goo.im Downloads - Downloading cm-9-20121214-EXPERIMENTAL-s7-asturel.zip
is netflix a online stream thing? coz its handled somewhere else and its way harder to fix
I test it and HW video decoding now works ..it plays HD
I test it and HW video decoding now works ..it plays HDbut now old bug again..home button does not work..you probably forget something or use some older build
fixed in v2, wpa_supplicant.conf also missed
winston_wolf said:I tested v2 and it works great, but still no hw video in mx player and netflix freezes while playing but stays responsive. i get sound for one second and black screen then it stops. with cm10 i had sound but no picture, just black screen but it was playing. and yes netflix is online streaming thing. im not sure if it is avaiable in your country but let me know and i can organize one month free account for you if you need it for testing ;-) should work if you can use different dns in your network. oh yeah one more thing wifi signal indicator stays grey and doesnt show signal strength but that is just small detail and doesnt really bother me
Did you do full wipe..mine s7 freezes completly from time to time (that old CM9 was fully stable) and almost alway when it is sleping
I have hw decoding in mx player (maybe you did not option in settings) and it works in continios play but if you try to jump try video it will sometimes fail (in you tube also) ..probably dont have enough baffer memory.
Edit: I try wiping bit the same ..when tablet goes to sleep it want wake up.
Full wipe done.
Mine didn't freeze at all just netflix and sometimes youtube, no problem with sleep, battery life is good but with cm10 i think it was still better, every app I tried works, unlike in CM10 but that's JB so not every app is compatible yet.
Like I said my biggest problem is with netflix since that was the most often used app by me. MXplayer plays in hw mode but only from certain websites with "educational" ^^ videos (mp4), will not play in hw mode "playing god" in avi for example.
Andreno 200 chip does not suport xvid,divx in hw mode ..so you wound not play it in hw mode and on stock rom... There is no netfix outside US but IMDB app plays 720p videos no probem..do not why netflix is so special..i have some local app for playing cable tv chanels on android devices and it work and streams perfect.
I'm just back on stock rom and it plays the same movie in hw mode. Netflix is available outside us and there is a way to watch it anywhere in the world. Why is so special? It isn't. It's just convienient with something like 14000 TV shows and movies available without breaks and commercials and like I said it is the most used app by me. I don't really care about hw mode in mxplayer for example because it plays videos just fine in sw the only thing is I read somewhere that black screen in netflix has something to do with hw accel.
Like i said before asturel has done great job bringing cm9 and cm10 to s7 and they work very good. The only thing stopping me using it full time is netflix incompatibility which for some won't be an issue at all.
Chipset | Qualcomm QSD8X50 Snapdragon | Qualcomm QSD8250 Snapdragon |
CPU | 1 GHz Scorpion | 1 GHz Scorpion |
GPU | Adreno 200 | Adreno 200 |
hey asturel,can you modify or port rom from device with similar chipset like HTC HD2? ...i have HD2 and IDEOS S7-201u Slim and i can test if you can do something about it... its just an idea but i dont know anything about developing roms so thats why i ask you...i can provide you links for HD2 roms like Paranoid,AOSP and similar...
this is chipset comparison,on left is for IDEOS S7-201u and on right is HTC HD2:
Chipset Qualcomm QSD8X50 Snapdragon Qualcomm QSD8250 Snapdragon CPU 1 GHz Scorpion 1 GHz Scorpion GPU Adreno 200 Adreno 200
i hope that this is posible to do and i thank you for your work so far... cheers![]()
i dont get what u want
made cm10.1 to boot, but there some issue with the touchscreen what i need to fix before i could do anything![]()
