sharpe351
- Jul 2, 2011
- 337
- 8
Distance between Tablet and Linksys, vs. distance between Tablet and phone running as wifi hot spot? Each "update" of non-factory ROMs is simply substituting drivers from similar-but-not-identical devices, so we are inheriting (sort of) "impedance matching" problems.
Is the Linksys capable of "n" speeds, or just "b" and "g"? Newer routers confuse the Tablet...
My router is a little archaic. Pretty sure b and g. I can be standing right next to it. Still drops. Could there be a substitution made in the code (from previous versions) to fix wifi? Found also that no other devices can connect after wifi quits on this device. Is the router crapping out, or is my tablet causing it?
Sent from a rooted SuperPAD clone with Android 2.2
