You can just go to the settings and tell me which text to translate:
hopefully its a proper native translation and not google translate.
example:
KKMod Tweaks = <spanish text>
Reboot Device = <spanish text>
I flash my IMX515 tablet in correct order (first 2.3.3r3 with KKMoD ROM KIT and second 2.3.4r3, Date Correction active). The tablet fly now....but I find an important error....my tablet wifi do not work, not connect as My android phone (i9000) connect right... I try change date (as I read in other post) and after putting correct date....rebooting everytime...and nothing...today I flash it with bluetooth patch....and nothing... When I enable de wifi in few seconds disable alone.(Airplane mode is disable) Can you help me?..I am desperate... If I make something wrong please correct me.
Important: I have installed ADB in my PC and in my laptop...none of them recognizes the tablet for connect...
Boot up fresh and immediately turn on wifi. Save a copy of the kernel log(dmesg) from the androidos application that come with the rom.
Hello again....here attached two test of all....
Can you help me please?...I do not know what I can do....
OK thx 4 all....my tablet flys now...very good work...and thx 4 reply my post...
The version r3 (not rc3) works prefectly...
I want to make a recommendation to change .... for the next version, I recommend change Launcher....Actually ADW but GO LAUNCHER EX with ICS THEME... it is really cool!!
One problem in R3 version is android market (v3.3.11)....actually (for automatic update) it install v3.4.4.. and this installed version do not work in your rom...
Temporal solution...install previous version...enter in command mode (terminal emulator) and enter this:
$ su
# pm disable com.android.vending.updater
this command every boot and before connect to internet...it sucks!!!!...do you know another solution?...
