- Mar 16, 2011
- 361
- 77
- Thread starter
- #121
Thank you,upgraded to the "r2",adw theme and bluetooth no problem
can you post the dmesg when you connect the bluetooth? like to know what bluetooth dongle that you have?
设备描述 Generic Bluetooth Radio
设备 ID 0A12-0001
设备类别 E0 / 01 (Bluetooth)
设备协议 01
支持的 USB 版本 1.10
当前速度 Full (USB 1.1)
Billionton USBBT02 Bluetooth Class 2 USB Adapter Windows Driver, Software | Wireless Driver & Software
v2.3.4 release 3 is out (market v3.3.12, remapped hardkeys,added recent apps softbutton, kkmod tweaks->shutdown device)
Like the hardkey set up.
Sent from my IMX515-8I using Android Tablet Forum
My wireless mouse works perfectly.
Hi everyone, and thanks a lot, KillerKink, for taking your time trying to improve our imx515 tablets!!
I have a FR 809 IMX515 tablet, two speakers, no screws. It runs currently the modded for two speakers XAUMOD android 2.2 rom without a problem so far.
I'd love to install your gingerbread rom in my device instead, but there are some doubts troubling me (I know I might be really mistaken, please notice I am quite new in the android universe..):
My device is unable to connect using adb, using the otg usb cable, computers doesn't recognize the device. I thought it might be that my otg cables where defective, but had the chance to test them in another imx515 tablet and worked.. Reading your initial post, I assume I need to have adb working in order to install KKMOD rom utility BEFORE installing your rom. Am I right?
In this case, is there no other way to update recovery (example given, installing your recovery booting from my existing recovery) and then update your rom from recovery as well, avoiding ADB?
I could help gladly with your spanish menu translation, if you give me the text to translate. I've noticed there's a couple spanish translations in the previous page, but I guess there's a lot more to translate hehehe
KKMod Tweaks = <Ajustes KKMod>
Reboot Device = <Reiniciar dispositivo>
Thanks again for the huge and good work!!
Thanks for such a fast reply!!
I could update my tablet to XAUMOD's because all I had to do was copying the image and updating from the standard recovery menu. As I mentioned before, the tablet is not properly detected by computers, so I can not access the media or use adb using USB. I managed to connect it through adb wirelessly (device wasn't found in the android sdk, anyway) using adbwireless, but that was of course executing the program with the tablet up and running.. if adb has to work in recovery mode, there is no way to use adbwireless...
For the second method, device is rooted but I think it has not busybox (if I'm not wrong, I recall titanium backup stating a long ago it didn't have busybox.. I will check it out once I'm home) but again, if adbwireless can't do the trick. The 2.3 rom need a different bootloader from that of the 2.2
To flash the kkmod bootloader I need adb too, right?
Regarding the spanish translation, I guess it takes me to install it in order to see which lines are missing, right? Otherwise, if you knew the lines to translate, I could do it right away!!
Thanks again for your time and attention, it's great how people can learn, improve and help each other through online boards.
Only thing is that there is no more hardkey menu. New key controls made the tablet more useful as a media device and still good with other things.
pic? url? brand/model?
