[ROM] KKMod GB ROM for 8" IMX515 - v2.3.4
Date and time are good. Bluetooth not working tried to send picture again to see if it would turn blue tooth still say I'm in airplane mode but I'm not. I'm on wifi right now.
Ill get you the info from the rfkill as soon as I can.
Sent from my imx51_bbg using Android Tablet Forum
someone reported that facebook will force close after first use.
Well I just looked the android version says 2.3.3 did I flash the wrong image. Im sure it was from the down load link and said it was 04. It says 2.3.3 in build prop dang it.
My facebook is working fine.
Have you try opening and closing the facebook and does it still work?
Nah. the version is cosmetic and is due to my laziness. I used the build.prop from v2.3.3. Thats is how some chinese tablet vendor fake the version. It just simple editing the build.prop.
I will work on the comestic changes after all functional issue are fixed(at least those fixable).
Been in and out of facebook 4 times I think.
2.3.3 thing is fine making sure I flashed the right image never know with me.
So far everything is working great ( minus the known issues ) I'm thrilled date and time are sticking.
Sent from my ERIS using Android Tablet Forum
Tried fix permissions reboot no help facebook has alway been shakey in my opinion normally they update itll run fine for awhile then crash out.
Cleared fb cash forced stop restarted its running ok again.
2.3.4 is based on freescale10.3.1, so what is 2.3.3 based on?do you know what features that are not supported by 2.3.4?
thanks a lot!
thanks a lot!
kkmod 2.3.3 is based on r10.2
Dont understand what you mean by what features is not support by 2.3.4.
I tried to add AD_HOC network for about an hour not sure what Im messing up can't get it to work. Hope your having better luck.
