[ROM] KKMod GB ROM for 8" IMX515 - v2.3.4
my tablet run into the same problem when upgrade from 2.3.3 to 2.3.4 b4. it is stucked at the kkmod gingerbread logo. imx515 with single speaker.
can you please re-share the KKMod-IMX515-ROM-ToolKit.iso on 115?
"adb shell wipe data" will solve the issue and I have already shared.
I tried to add AD_HOC network for about an hour not sure what Im messing up can't get it to work. Hope your having better luck.
Will test it when I get the chance.
btw, maybe you can consider trying out wifi manager.
I have a new tablet on the way Acer Iconia but I'm gonna keep working on this one for sure. I really like this tablet. I have a Droid Eris running 2.3.7 and Cm7.1 I like the underdogs.
Sent from my imx51_bbg using Android Tablet Forum
I know, but I don't have romkit v1 on hand and it was expired on 115.com.
BTW, I'm in China mainland, and cannot access Fileserve.
Thanks for your help.
per my earlier post, I have already shared.
WiFi manager see's the ad-hoc connection but cant connect.
ok, guess will have to wait till its tested.
Ill get that flashed asap!!!
Sent from my A100 using Android Tablet Forum
take note though that I havent gotten the chance to test adhoc as my notebook is not setup since it always hung on win7. going to try on ubuntu
My laptop just hung downloading updat zip have to flash when I get home.
Sent from my ERIS using Android Tablet Forum
RC1 flashed ok using recovery.
Tablet boots without problem after a data wipe but wifi gives me an error when turning on. logcat just says: "E/WifiService( 2281): Failed to load Wi-Fi driver."
Any ideas? Thanks.
Update: some more info from adb shell dmesg after wifi error:
<4>ar6000_pwr_on --enter
<4>111111111111111111111111111111111111111111 steven
read_mac_addr_from_file: file /system/lib/firmware/ath6k/AR6102/softmac filp_open error
<4>eeprom_ar6000_transfer: read_mac_addr_from_file failed
<4>eeprom_ar6000_transfer: mac values in eeprom array
<4>[0x0],[0x25],[0x68],[0x1],[0x2],[0x3],
<4>AR6000 Reg Code = 0x40000060
<7>Waiting arm_podf enabled!
<3>init: no such service 'wlan_tool:load'
<3>init: no such service 'wlan_tool:unload'
I boot in using home and menu key it goes to recovery screen and does nothing what am I missing?
Never mind I can't read Lol
