[ROM][WIP][AMPE][NOVA] Phoenix A31 1.00
Actually I have rooted and used ES file manager to copy files and edit build prop. Nothing else and everything works fine on all setups. No chmod what so ever
Good to know, enjoy.
Incoming compatibility run, just letting tablet firm up more as I had to superglue the case shut from the ****ty craftsmen work done on the back of the NOVA 10 which is the prototype for the AMPE / SANEI 10.
Confirmed Working
DirectX 9 Shader
OpenGL 1,2,3
WebGL Not native at this point.
Tragidy Can I get your thoughts on this tablet in generel. Performance wise are you happy with it? How's the screen not being IPS? I purchased this tablet because of the price. 185 with a leather case shipped by dhl. Just waiting on it to arrive.
Tragidy,
Has the source code for this tablet's firmware been released? If so, I'm think that the driver for the power management chip (if it as one) can be ported over to the Onda V972? Members had installed firmware from the Novo 9 and Chuwai to the Onda v972 and everything work, EXCEPT the screen. Obviously screen driver issue. Anyway, if possible do you think you could exact it and upload it here? Thanks
Here is all the XML files copy these to system/etc/permissions/
Also in you build prop change manufacturer to samsung.
This setup has worked on all my devices. i am able to see and install all apps including tune in radio.
Hey dude I tried these files, still does not work on this tablet, I did at first completely replace all files, but that breaks wifi and other things, so then I reset tablet to default and added them, and still no tunein radio or gta 3. Yes I edited the build.prop too
Ok here you go these files will work.
Copy and paste them into the permissions folder, DO NOT OVERWRITE any original files in the tab, only copy the missing files, the only one you do overwrite is tablet_core_hardware, all other files remain original, otherwise you will break operation of other systems on your tablet.
For me now, tunein radio, gta vice city, gta 3, all show up in android market as device compatible.
I also changed manufacturer to samsung just in case
P.s I got these files from supersport rom for the u30gt tablet.
  • $permissions.zip
I had a chance to test these, worked good on my end thanks.
I will test yours tonight on my next build before i push it with ADB
I can confirm the first batch of XML posted will pose issue, avoid on NOVA
On another note...
Custom rom coming soon!
World First
root@plox atrage -u image.img
unpacking image.img to image.img.dump
Extracting: COMMON SYS_CONFIG100000 (49319, 0)
Extracting: COMMON SYS_CONFIG000000 (3101, 0)
Extracting: COMMON SPLIT_0000000000 (512, 0)
Extracting: BOOT BOOT0_0000000000 (24576, 0)
Extracting: 12345678 1234567890BOOT_0 (20992, 0)
Extracting: 12345678 UBOOT_0000000000 (434176, 0)
Extracting: 12345678 1234567890BOOT_1 (270336, 0)
Extracting: UPFLYTLS XXXXXXXXXXXXXXXX (150896, 0)
Extracting: UPFLTL32 XXXXXXXXXXXXXXXX (137920, 0)
Extracting: PXTOOLSB XXXXXXXXXXXXXXXX (167424, 0)
Extracting: FES FES_1-1000000000 (568, 0)
Extracting: FES FES_1-2000000000 (6312, 0)
Extracting: FES FES_200000000000 (1964, 0)
Extracting: FES FES_000000000000 (85904, 0)
Extracting: FET HW_SCAN_00000000 (187760, 0)
Extracting: FET UPDATE_BOOT0_000 (171696, 0)
Extracting: FET UPDATE_BOOT1_000 (194560, 0)
Extracting: FET FET_RESTORE_0000 (4592, 0)
Extracting: FET MAGIC_CRC_START_ (128, 0)
Extracting: FET MAGIC_CRC_EN_000 (128, 0)
Extracting: FET MAGIC_DE_START_0 (128, 0)
Extracting: FET MAGIC_DE_END_000 (128, 0)
Extracting: FED FED_NAND_0000000 (196512, 0)
Extracting: 12345678 1234567890CARDTL (81920, 0)
Extracting: 12345678 1234567890SCRIPT (2014, 0)
Extracting: 12345678 1234567890___MBR (65536, 0)
Extracting: 12345678 1234567890DLINFO (16384, 0)
Extracting: FET CARD_UPDATE_BOT0 (20912, 0)
Extracting: FET CARD_UPDATE_BOT1 (19840, 0)
Extracting: FED CARD_FED_0000000 (27216, 0)
Extracting: FET CARD_HW_SCAN_000 (18624, 0)
Extracting: RFSFAT16 BOOTLOADER_FEX00 (6020096, 0)
Extracting: RFSFAT16 VBOOTLOADER_FEX0 (4, 0)
Extracting: RFSFAT16 ENV_FEX000000000 (131072, 0)
Extracting: RFSFAT16 VENV_FEX00000000 (4, 0)
Extracting: RFSFAT16 BOOT_FEX00000000 (10414080, 0)
Extracting: RFSFAT16 VBOOT_FEX0000000 (4, 0)
Extracting: RFSFAT16 SYSTEM_FEX000000 (423257000, 0)
Extracting: RFSFAT16 VSYSTEM_FEX00000 (4, 0)
Extracting: RFSFAT16 RECOVERY_FEX0000 (10891264, 0)
Extracting: RFSFAT16 VRECOVERY_FEX000 (4, 0)
What do u honestly think of the a31 CPU?.
Greetings,
After using it hands on for over a week now, I can say that I'm impressed with the GPU beyond words, however the processor as we already knew is not that pimp but its really good on battery life.
I think all in all if you buy an authentic vendor-ed item like momo/ployer or your prefered brand item.. its a good purchase and its cost effective
