- Thread starter
- #61
Ok here you go these files will work.
Copy and paste them into the permissions folder, DO NOT OVERWRITE any original files in the tab, only copy the missing files, the only one you do overwrite is tablet_core_hardware, all other files remain original, otherwise you will break operation of other systems on your tablet.
For me now, tunein radio, gta vice city, gta 3, all show up in android market as device compatible.
I also changed manufacturer to samsung just in case
P.s I got these files from supersport rom for the u30gt tablet.
I had issues using this pack it disables wifi.
ROM Highlights and Features
Release One
- Initial First Release, don't expect miracles!
- Flash-able with Phoenix Suit!
- Rooted
- Market should be 99.99% complete
- Default English ROM
- Super User APK Implemented
- GPU will now use all 8 virtual cores even on older GL games
- Default 1104mhz up from 1008
- Various Kernel Optimizations
- YouTube HD
- Preloaded hosts file
- DEODEX
- Zip-aligned
- Market Enabler Region Unlocked
- PatchLucky Adobe Flash Hulu!
- Many other small tweaks.....
Known Bugs and Issues
TBD
Roadmap
Plans to expand upon the kernel and operating system to 4.1.2 or 4.2.1
Change partition for system to 2.0GB instead of 1.0
Overclock past 1.25ghz
Update Play / Services / Search / Gmail
Release One
- Rooted
- YouTube HD
- DEODEX
- Zip-aligned
TBD
Roadmap
Great job Tragidy, just had a few questions on the rom. Did u notice anything on a power management chip when u were fixing the kernel? Also, how did u assign ram usage? Do the system still only use 512 or 1gb? And lastly did see away to put the gpu at its max of 16 cores? Thanks in advance
Sent from my SAMSUNG-SGH-T989 using Tapatalk 2
P Name | ![]() |
![]() | Description | ![]() |
![]() | Portability | ![]() |
![]() | Process Node | ![]() |
![]() | Type | ![]() |
![]() | Maturity | ![]() |
![]() | Overview | ![]() |
![]() | Features | ![]() |
![]() | Deliverables | ![]() |
![]() | Market Category | ![]() |
![]() | Datasheet | ![]() | ||
![]() | Bus Interface | ![]() |
POWERVR SGX544MP2-16 GPU graphics processor - Imagination Technologies - 4-pipe/core, 2-16 multi-core Series5XT 3D/2D/vector graphics including DirectX 9 full Feature Level 3 Support - IP Catalog : Digital Core IP : Audio/Video : Other IP Catalog : D
This is actually a 16 core gpu, but if you read on it, you will see that it can actually be configured from 2-16.
P Name ![]()
POWERVR SGX544MP2-16 GPU graphics processor ![]()
Description ![]()
Portability ![]()
ASIC, Structured ![]()
Process Node ![]()
all ![]()
Type ![]()
Soft IP ![]()
Maturity ![]()
Silicon proven ![]()
Overview ![]()
The PowerVR SGX Series5XT Graphics Processing Unit (GPU) IP core family is a series of highly efficient graphics acceleration IP cores that meets the multimedia requirements of a wide range of next generation consumer, communications and computing applications. PowerVR SGX Series5XT architecture is fully scalable for a wide range of area and performance requirements, enabling it to target a wide range of markets from low cost feature-rich mobile multimedia products to very high performance consoles and computing devices. ![]()
Features ![]()
- Most comprehensive IP core family and roadmap in the industry
- New USSE2 delivers twice the peak floating point and instruction throughput of Series5 USSE
- YUV and Colour Space Accelerators for improved performance
- Upgraded PowerVR Series5XT shader-driven tile-based deferred rendering (TBDR) architecture
- Multi-processor options enabling scalability to new levels of performance
- Support for all industry standard mobile and desktop graphics APIs and Operating Systems
- Fully backwards compatible with PowerVR MBX and SGX Series5 families
Deliverables ![]()
- Synthesisable RTL
- API Drivers: OpenGL ES 2.0/1.1, OpenGL 3.0, OpenVG 1.1, DirectX 9, OpenCL Embedded Profile
- OS Support: Linux, Symbian, WinCE, WinMobile, Android, Windows 7/Vista/XP
- Full documentation
- Comprehensive Developer SDK
Market Category ![]()
Automotive, Communications, Consumer Electronics, Data Processing, Industrial and Medical, Military/Civil Aerospace, Others ![]()
Datasheet ![]()
Bus Interface ![]()
AXI, OCP, IMGBUS
