Pat, what roebeet has done--at least with BoS and perhaps also some of his other ROMs--is replace stock recovery with CWM. So I find that as I'm flashing through various ROMs, sometimes I see the CWM recovery! I should be more attentive to which builds have it, but my strategy thus far has typically been to nvflash (take it back to stock), and then add on from there. I agree that the CWM-approach is clean and usually easier, but in my case I've had to wipe data (full wipe) enough times that having CWM backups hasn't been an option.
-Matt
The part that I navigated around was the bootloader. I'm assuming that since the 1.1 and 1.2 branches have different bootloaders, that nvflashing with the corresponding base image moves you from one bootloader to the other (i.e., it installs bootloader, recovery, and ROM aka OS). But what happens to the bootloader (and how it's represented in memory) during other forms of flashing...that's still a blur!Matt, that was perfect. That's what I understood it to be, but what you said really clarified it for me. Thanks!
Hah, you should have seen me the day I decided to root my Droid!!! I was TERRIFIED! I was sure I'd permanently destroy it...but it all worked out. And I think the gTab has turned out to be the more forgiving device of the two, in terms of the mistreatment it endures.Take your time, and don't let me (or anyone else) rush you! No point in taking the next step until your comfortable (says the most neurotic guy in the forum!).
(FWIW, I have had near-perfect stability with BoS 4.0. The three things that don't work are: camera, Flash, and hardware video acceleration. None of those happen to be deal-breakers for me, so 4.0 has become my daily-use ROM. In particular, it's not soft-booting like the 3.x versions did, and wifi is rock solid. Anyway, that's my experience so far. I know if I started reading the gigantic BoS thread at slatedroid from scratch, it would be nearly impossible to sort out how each update of BoS performs!)
-Matt
Matt,
Wow, that BoS does look amazing. I'll probably wait till I'm not such a newbie to try it since it seems like it's not fully stable yet, but by following your suggestions in the post above I'll get there. Thanks for the advice. I don't mind reading, but it's nice to have a place where some of you "vets" don't mind pointing us new guys in the right direction. Thanks again!
Pat
Pat, to be honest you should take what I say with a grain of salt (trust but verify!). Not to undermine myself, but since I can't meet you at Starbucks to help out, you should proceed at your own pace! In any case, generally flashing a ROM in PC terms is like replacing/modyfing the OS, while the BIOS is left alone. I'm sure that's either a rough analogy, or only partly true. The rub is which parts of the filesystem you are replacing. My sense is nvflashing replaces BOTH the recovery system and the ROM, while flashing the ROM (USING the recovery/update) system only replaces the "OS".
Tom, my apologies for not being clear. Each ROM has it's own particular base. VEGAn (last I heard) is 1.1, while roebeet's newer builds (BC and BoS for example) are 1.2. So again, to use VEGAn I'd recommend nvflashing the 1.1 base image (gtab.nvflash.1.1.branch.20110422.zip) and then flashing VEGAn from there (Dave has a great how-to on doing that!)
Both of you, please keep us all posted!
-Matt
Tom, did you downgrade to 1.1, or are you still at 1.2? If you downgraded, let me know if the ROM above works for you. It's one of the ones I couldn't get working and had to go to an earlier version of vegan to get my tab running.
Check your apps and see if you have Spare Parts installed. If so, one option is to turn off "Compatibility Mode" at the bottom, which may help (unless of course you're not running it, or it isn't checked!).I did the same thing as you did. I downgraded to 1.1 and then tried the newer version of VEGAN.
So after discussing on this thread, I went home and put the VEGAN 1.00 BETA 5.1 on and it worked.
Couple of things. I do not like the look....sorry I'm picky. When I install an app from the market it looks stretched. I know I know it was developed for a phone not a 10.1 inch table. So now I am looking into do the nvflash and trying a newer version. I'll let you know what happens from there.
