WiFi problems
this is really puzzling - so it is not necessarily a wifi problem since you are able to connect at will on other routers might it be something else then - perhaps an dns issue or ip conflict
did you try forgetting the network connection and let the nook find it again?
Since the SSID is hidden, the NC can't find it.. You have to put it in manually. But yes, I've forgotten it and re-entered everything. My phone is using the exact same settings. One works, one doesn't.. I'm thinking about taking my wife's NC to work and seeing if I can get it to log on.. If it works, then the problem is with my device. If it doesn't, then it's with the network.
