- Nov 8, 2011
- 3,836
- 1,394
- Thread starter
- #31
Will this rom work on a 7022?
Sent from my T-Mobile G2 using Tapatalk![]()
No, it wont work on 7022.
hey vampirefo i tried your little tip for finding out if my tablet is boot or boot1
i got "goodix 12c test ok"
so this means i cant use this rom ?
its lookes realy good tho nice find
for search click the magnifying glass,then on top right click 3 small squares then click settings, then uncheck first one, google search suggestions, now it should work.
wifi works fine for me, I would thinks it's faster than stock, not slower.
aura doesnt work with the goodix but i made a frankinstin build for us goodix peoples.. check it out
Download 7042_update1.zip from Sendspace.com - send big files the easy way
dsp is working - not with pandora though
framework and launcher pulled from aura i edited framework battery icon. some other misc stuff
works good on my 7042 havent had a crash yet. order and chaos works although none of my ea games do =/
dymedog said:Thaks again for the help. searchis working perfectly.
Sounds good I am currently looking at aurora_feiyu_mod_(0622), may port it to 7042, and 8042 if it suites me.
aurora_feiyu_mod_(0622) seems to run really well on my 7042, it has less apps then Mobiz V.2, it takes a while on first boot to get everything settled, then it's smooth.
The 7042_boot provides permanent root, and forces adb to su permanently. Coby has modified their boot.img to prevent permanent root. So I undo what Coby did.
rsk002 said:I was able to get permanent root without flashing a new image. I simply moved su from /system/xbin to /system/bin. While I do have to explicitly "su" when connecting with adb, I have encountered no other issues and was able to install gapps and everything else. Are there any downsides to my method?
I will look into int.d support, I am already overclocking my 7042 and 8042.pimpinez said:its 4.0.4 cool! hey vampire is there any chance we will see a kernel with int.d support and mods because the stock kernel is kinda bunk. id like sio and vr i/o's. interactive seems broken it just locks at 100% like performance and it overclocking/undervolting would be sweet!
