- Nov 8, 2011
- 3,836
- 1,394
- Thread starter
- #46
If you install superuser you have to go into it's settings and update su. I have no problems with custom boot animation.
its 4.0.4 cool! hey vampire is there any chance we will see a kernel with int.d support and mods because the stock kernel is kinda bunk. id like sio and vr i/o's. interactive seems broken it just locks at 100% like performance and it overclocking/undervolting would be sweet!
cool i used a modified debugged on my rom ima give this a try!added 7042_init.d_support.zip to first post, should work on any android.
vampirefo. said:I haven’t yet seen a tablet default to portrait mode, if your did, sounds like a problem off the bat, a tablet is just too big to default to portrait mode, it's default landscape mode, perhaps you should go back to stock and test it again. This rom uses only the su binary as root, if you want superuser app you can get that from market. upload your boot animation so I can test it on mine. google play shortcut? I have two of them, one on main screen one in app folder both work.
I have found an app that allows the tablet to be locked into any or orientations, just tested the app, it can indeed lock the tablet in portrait mode.
https://play.google.com/store/apps/details?id=com.googlecode.eyesfree.setorientation
ziggyzag said:Ok so Ive realized now that anything from my list of boot animations (in rom toolbox app) that says "tablet friendly" will make the default plain android animation be the boot. The animations that do work are portrait ones that the tablet flips to landscape while cutting some it off. Almost like the tablet is forced into landscape mode. All i know is this, in the stock rom the tablet boot animations work. Also in the stock I noticed if your using the tablet with auto rotation on and then turn off auto rotation it stays in portrait (but slide screen stays auto as in this rom).In this rom once you switch auto rotation off it goes to landscape. This rom seem to have an affinity for landscape for all things, the boot and auto rotation deals seem connected.
Correction: its not all the the tablet friendly boot animations in that list, out of the four i tried 3 failed and brought up the default. I know one for sure worked on the stock. If you feel like trying it vampirefo its tablet machine azul in rom toolbox boot animations. I have tried just copying it with es file explorer into the proper folder but it failed to load.
catscase said:Hi all
Does anything for 7033 ?
It is a tablet very near from the 7022.
thanks
vampirefo. said:I don't have a tablet with goodix, so I can't say this rom would work or not. If you have cw recovery installed you could make a back then try this rom and post back. you can always use cw recovery to restore your backup.
I will look into that rom as soon as time permits.Hey vampire, is possible a version from the Mobiz v3 ICS 4.0.4 for coby 7042? tks for port Elvish 0.4![]()
I installed the ds version of this rom after flashing the ds boot image and partitioning my sdcard. I like the rom and it works great except that it doesn't see the fat partition on the sd card. When I boot into recovery, cwm defaults to the fat partition. When I mount the storage to the computer, the on phone 1.2 GB file system and the 10GB fat partition show up. The ext4 partitions no longer show up, since flashing the ds boot image (which is expected). In settings /storage, sdcard showed up as mounted, but didn't have a size or any info. It stayed the same after unmounting and remounting. To clarify, this is on the 8042.
Thank you for all the work that you have done on this device.
