hctablet1024
- Dec 20, 2011
- 6
- 1
False alarm!
Still with batery issues.
Maybe the problem is my expectation.
After all, how much time does a full charge last with wi-fi on and blank screen?
I full charge, use for +/- 1,5 hours (with wi-fi on), put it on standby (black screen) with +/- 85% batery (1 press of the on button) and the day after, 24 hours the full charge, the batery is completely empty.
Is It right or what? As I tested, with Wi-fi off manualy before sdandy, It last a lot more.
Thx in advance.
In regards to juice defender, it has to be enabled after the install. When the tablet is turned on, there needs to be a shield with a red dot which means all radios have been turned off.
If the red dot and shield is there then the wifi is getting turned off, the wifi might not be the problem.
When the ROM was installed, was the battery fully charged before the install? I shutdown the tablet and let it charge until the light is blue, then power up and let it charge again until the power light turns blue after a reboot.
The level of your battery charge at the ROM install will become the 100% charge level. When the battery drains, the tablet will shut off before 0% even if in reality you have a lot of charge left.
My battery is lasting days if I don't use the tablet often. I think your expectations are normal. The battery should not drain overnight unless widgets are running or there are radio signals.
