For some reason, when I check the use GPS satellites checkbox it just flickers on and off. it used to be able to be checked. Does anyone know if this has changed. Trying to use tethergps and I have to be able to check the box.
Evan
AFAIK, the MID 1024 does not have GPS. So, it is useless even if you can tick. turn on the "switch for GPS. Unless you have a BT GPS device or a USB GPS device. Personally I haven;t tried hooking a GPS device on my 1024.
