[CFW] GingerLF EVO - Custom GingerBread Android 2.3 for MID1024
Good Morning All!
Update: Tablet is still working super fast. I have the Asus Transformer (TF101) also. I have them side by side, and the Kyros 1024 is actually faster! It cant touch the transformer in benchmarks, but all in all its actually completely awesome. Oh, I picked it up in perfect condition on craigslist for $60 too.
Soooo, the only "issue" I really have is accidentally touching the "Browser" and "Search" soft buttons. I have heard there are means to do so, and have followed a couple of threads on the matter, but cannot locate the correct files in the system menu to alter. I am using the EVO 1.5 ROM. Can someone please shed some light on this matter?
Thanks alot!
Setipollux. Steev made an app that runs with Python scripts that does it automatically....
browserkey.zip - 4shared.com - online file sharing and storage - download
go tot he market and download Python. Run python and hit the install scripts button. it will download an install I think 5 zips. once done, run the app I just linked to. it will have a toast popup that says disabled. reboot and you are done.
Once again.. Awesome! Both the Browser and Search Buttons are disabled.
Great work Steev and Pickupman66.
ok so if we do that it will disable the browser and search buttons right? how to enable it again? cause i want to install it and disable those two buttons.
cause titanium back up doesnt work for me even if i freeze the browser button. anyway link2sd have the same option in disabling too.
just want to ask hows your memory after flashing to lF EVO v1.5???
Im currently using 1024n tested 8 multi touch. same with mharckk i guess... attempting to flash to evo but before i flash my current and stock firmware is gingerbread 2.3 my nand 2.85gb available space 2.02gb internal storage available space 279mb... may i know what will be the diff after i flash the evo rom?? will my internal storage increase?? or the nand?
my problem with this stock gingerbread 2.3 i cant download to android market, i only download games and apps to getjar. the evo can download in android market right... thats why i'm tempted to flash hehehe.
last question can i restore my stock gingerbread? or is it the same as the rom that coby kyros released recently?
The memory is good. Plenty of internal storage. Yes it comes with the android market. You will need your stock gingerbread image to flash back.
Sent from my SCH-I905 using Tapatalk
Hi sir tnx for the reply, how can i backup my stock rom? May i know what's the capacity available in your nand and internal memory after patching lf evo v 1.5??
Nand memory if u have a 4gig capacity will be 2.90Gig, and the internal will be 1.5Gig
also the firmware released by coby is only for 2.2 version, sadly i dont have backup of original gingerbread cause i dont know how, anyway i dont need to flash again, but if someone can upload a back up original rom it will be much appreciated. :)
when i flash the 1.50 evo i edit the ram capacity into 1025mb only so that i have more nand memory. :)
My 1024 Tab is still going strong. re-flashed min elast week as I installed some junk applications and it wrecked havoc o nthe tab.
So far so good. Only thing I observed when using #g dongles (I have a Huwei E-160 HSDPA stick) is that it tends to turn-off the tab or reboot it every now and then (but not to frequently). Maybe a fault on the USB 3G dongle or something else.
Hello,
I have a MPMAN 1027 too and I can't manage to launch installation process.
My tablet is stuck on MPMAN logo screen. I need to use reset hole to make it reset.
Then I hold Power+Home (Silver circle) but is still hangs on MPMAN logo.
Any advice ?
Good Morning all! Anyone know if there is onboard bluetooth with the 1024, and if so is there a way to enable it?
Hello,
Any advice ?
Hi,
I have MPMAN 1027 8GB too. I use 4GB SDCARD for upgrade.
False alarm!
Still with batery issues.
Maybe the problem is my expectation.
After all, how much time does a full charge last with wi-fi on and blank screen?
I full charge, use for +/- 1,5 hours (with wi-fi on), put it on standby (black screen) with +/- 85% batery (1 press of the on button) and the day after, 24 hours the full charge, the batery is completely empty.
Is It right or what? As I tested, with Wi-fi off manualy before sdandy, It last a lot more.
Thx in advance.
As I tested many configurations before, and after juice defender the problem disapers, I conclude that juice made all the magic.
