Coby Kyros 1042 help
That is just what Coby gave me to try but none of them worked. I am not very good at programming so I am not sure what to look for to change the calibration. I did take a firmware dump before bricking my tablet. Here is the link to those files. Coby 1042 dump files.zip
This image seemed to work the best with my 1042 sun4i_crane_mid1042_120701(8GB)V1.img, which Prodina shared. The touchpad is indeed backwards. wireless does work now. it also works with a mouse using the usb adapter (or bluetooth i would assume)
Does anyone know how to calibrate this or if theres some way to manually edit the calibration file? Perhaps we can replace it with a good one.
I have figured out what the touchscreen behavior is
When you go up and down, the touchscreen thinks we're going left and right
when you go left and right, it thinks we're doing down and up
I am in the same boat here I used your offered IMG file it recovered all but the touch screen on my Coby Mid1042 so I am following your post like a puppy hunting a bone.
@freqenzy : Yes i have trouble with the wifi, impossible active.
My Coby mid 1042 buy during 2013 (driver wifi 8192.cu.uk).
if some body have StockROM for this version MID1042 with bug driver wifi 8192.cu.uk :rolleyes: (the old StockRom inside the forum don't works).
Thank for your help, have good week :D
