- Jan 6, 2011
- 5,172
- 899
- Thread starter
- #16
Need help with deep sleep state.
My nook color is setup as a dual boot. I use the latest B&N version and CM7 7.0.2. I installed cpu spy and it tells me that my CM7 Nook has never gone into deep sleep. Does the latest stable version of CM7 7.0.3 go into deep sleep? If not which nightly would you suggest.
Thank you.
7.0.3 Stable does not support deep sleep. Deep sleep first appeared in the nightlies just before 7.1.0 RC1 was made avaialble. Most but not all of the versions of the nightlies from that time on should support deep sleep. As is the case with nighlties sometimes working features get broken so that is why some of the nightlies may not have it. You can try the nightlies between about 140 and 155 which have been used around here with mostly success.
