PHIREMOD Discussion [ROMS] [Kernels] [Versions]
In theory I know that it has been dealt with.
What does this mean in true life?
What differences do you observe in everyday use in comparison to previous releases?How more time before empty battery?
For CM7 according to LocalStain it means double or triple the real world battery life with the same amount of usage. So from 8 hours or so of intermediate usage until a recharge to 2-3 days of intermediate usage before needing a recharge.
JP
JP
Sounds great! Let's hope v7 comes out soon.
I did the upgrade to v7 this afternoon and found that the android market did not work nor could I connect to a WiFi network with a hidden SSID even after its configured. I'm going back to 6.3.
My problem with YouTube under 6.3 was fixed by simply shortening the name of the device to "android" under "settings\applications\development\device host name" from "android-$(*&@#%^09827350@)(@*&%" :D
Changed ROM to Cyanogen and can now access hidden WiFi networks no problem.
Did U have this problem with previous Phiremod releases?
No problem with UT here.
Your problem was with UT app or watching UT videos from within browsers?
I a running 6.3 and two days ago when I plugged it in it didn't charge. Once I turned it off and plugged it in it will charge but it will not charge if it is on. I am really new at this and any help would be appreciated.
Sent from my Nooo Color using Android Tablet Forum
First time I hear this situation.
Are you sure its not a problem of your cable or the wall socket?
Okay so I am a noob but I didn't think that much of a noob!
Sent from my Nexus S using Android Tablet Forum
Any new information on Phiremod Nook V7 Test? Has anyone else tried it out? Any news on the testing versus stable version release?
It seems to me that Phiremod is a bit forgotten by creator
Sent from Nook Color on Phiremod 6.3 @1.3Ghz
I finally made the plunge to upgrade from v6.0 to v6.3. V6.3 is much better. The battery drain issues seem to be fixed with the newer version of CM7 and it is faster. I haven't had any wifi or issues with Market or YouTube. I haven't been on many different wifi networks though.
Imagine to go at latest nightly where the sleep matter is finally resolved and also Usb host is supported.
Sent from Nook Color on Cm7 Nightly 129 @1.350Mhz
