caulktel
- Jan 21, 2011
- 126
- 5
Were getting closer to having CM9/ICS on the Nook Color!
[DEV] CM9/ICS Work-In-Progress - xda-developers
Hi, I got a nook color for xmas and downloaded the latest B&N update. A few days after, I rooted my nook using the instructions and it worked fine.
I just have a quick question : do I need to keep the SD card with what I used for rooting (CM7, google apps, clockwork)?
After rooting I removed the SD card and my nook runs CM7 perfectly.
I would like to use a SD card to add music and videos. Would you guys recommend formatting the SD card or can I just copy my files (videos, mp3) on it and insert it back inside the Nook? I also have a brand new 32 GB class 4 SD card that I could use to play multimedia files on the Nook. What do you guys think?
So just what is this nightly turning into? CyanogenMod nightlies changelog for Encore Lots of reference to ICS in the changes, but just what is is going to be when it's done, CM7 or CM9? I've been watching this for a long time and its getting huge. Will it even run on the NC? So many ????
