Woo Hoo! Ice Cream Sandwich source code is finally available. Wonder how long before the CM gang will run with this.
Ice Cream Sandwich source code released, sync pending go-ahead from AOSP -- Engadget
Make your backups and try a fresh install. See if this seems to work ok before restoring your apps. When you do go to restore your apps you might want to leave out any apps that might be causing the problem and then add then one by one to see if you can find a culprit. Live wallpapers, battery monitors, task killers and the like come to mind.
The fresh CM7 install may fix the problem on its own. If not hopefully this will help figure out what is causing the problem.
I'll give it a try. I already did a fresh install but that didn't work. I'll try leaving out some apps. I don't use any live wallpapers or task killers. I have one battery widget I've been using for months with no issues.
Thanks for the suggestions.
My Nook is still going dark. The only way I can bring it back is by holding the power button down for 15 seconds and then pressing it again. I just did that and the battery is at 70%. I have no idea why it's doing this.
Sent from my Thunderbolt.
