Galaxy Tab Pro 10.1 problems with cyanogenmod
xandor
28
I'm trying to install cyanogenmod using the instructions posted here, but I'm not getting any luck.
I keep getting "Error: failed to send data!"
I've tried the libusb and libusbk drivers to no effect.
Here's what I get after running the heimdall command:
heimdall flash --RECOVERY clockworkmodrecovery.6051.picassowifi.img --no-reboot
Heimdall v1.4.0
Copyright (c) 2010-2013, Benjamin Dobell, Glass Echidna
http://www.glassechidna.com.au/
This software is provided free of charge. Copying and redistribution is
encouraged.
If you appreciate this software and you would like to support future
development please consider donating:
http://www.glassechidna.com.au/donate/
Initialising connection...
Detecting device...
libusbx: error [init_device] device '\\.\USB#VID_046D&PID_C226&MI_01#8&37159602&
0&0001' is no longer connected!
libusbx: error [init_device] device '\\.\USB#VID_046D&PID_0A4D&MI_03#7&6FDA8B1&0
&0003' is no longer connected!
libusbx: error [init_device] device '\\.\USB#VID_046D&PID_C531&MI_01#8&5C4189F&0
Claiming interface...
Setting up interface...
Initialising protocol...
ERROR: Failed to send data!Releasing device interface...
I've had no luck finding anyone else with a similar problem.
Any suggestions?
Meanwhile I managed to replace the ROM by rooting the device and using Odin via Windows. So if this is an Option for you just give it a Chance.
I Rom'd my tablet, installed twrp recovery and used that to flash cyanogen after doing the usual backups. Wi-Fi occasionally drops out, otherwise it's speedy
Sent from my Galaxy s4 using tapatalk
