Wow I didn't even see your post, it seems were having the same exact issue! FunnyHi All my nook is stuck on clockwork recovery. Not sure why. I was only completing a nandroid backup. When I go to reboot now. It starts to reboot but goes directly back to cwr. Nook is rooted and cwr version 3.0.0.5. HELP
I chose OLD, like the directions said :O... Now what do I do? Everytime I hit reboot system now it just goes back to cwr
Alright well I downloaded cwmr_3.0.1.0, I moved into the SD Card. Popped out the Sd card from laptop, placed it in nook.
I rebooted the system. Went down to apply update from sdcard, Install /sdcard/update.zip -- no such file or directory, installation aborted...
now what did i do wrong or did not do?
EDIT:
Well I found a place where it said to update from .zip file on sd card, I applied the update of 3.01.0 and it said install from sd card complete. Went back, chose reboot system now.... and waiting to see the results.......
ok now its in v3.01.0 clockwork mod recovery...
im hitting reboot system now again and its going into the device normallyit seems! but taking a while, still stuck on the android screen with the little green guy... errrr finally went through, but it's kind of laggy, slower than usual? how come?
Welcome.
Common problem when you perform a backup with CWM recovery and you rooted using autonooter 3.0. It messes up the boot.image file and never lets you boot out of CWM recovery.
OP was changed to new CWM rom manger and CWM recovery.
What you need to do:
If you DO NOT have the latest CWM rom manger 3.0.1.2:
-Turn off NC
-Remove SD card
-Load SD card to any card reader
-Download and copy to SD card, removecwr.zip file from HERE
-Download and copy to SD card, new CWM recovery 3.0.1.0: http://muffinworld.net/android/nookc...mr_3.0.1.0.zip
-Re-insert the SD card to the NC
-Boot to CWM recovery
-Install from sd zip: removecwr.zip (this will remove CWM recovert 3.0.0.5 and restore stock recovery)
-Reboot as normal
-Go to market and install latest version of CWM Rom Manager 3.0.1.2 or .3
-Reboot
-Reboot to CWM recovery
-Install from sd zip: CWM recovery 3.0.1 zip
-Reboot
-Enjoy.
If you do have the latest CWM rom manger 3.0.1.2:
-Turn off NC
-Remove SD card
-Reboot
-Enjoy.
rico/all,
New to site, been playing with rooted stock NC for about 2 weeks. All well so for until the CWR looping boot issue addressed many times here. I had B&N 1.1 so used autonooter 3.0. That is why I had the reboot loop issue as mentioned above in thread. So here is where I am:
- I used the CWR Removal directions (Thanks again for that) and have the rooted stock rom back up. However, it appeared to still show CWR still installed (from market).
- I could go into Rom mgr from app drawer as well
- Therefore I followed 2nd half of instructions quoted above (already have latest CWR installed). I downloaded the CWR recovery 3.0.1 and placed on sd, no problem.
- Booted up and selected the Rom mgr and hit 'boot into recovery'
- The boot failed with error. I did hard reboot into normal NC.
- I have uninstalled CWR via market and reinstalled just to be sure I have latest/greatest working CWR.
This is where my questions come in. With the state I am in now, should I follow the 2nd half of the instructions above to update recovery mod or should I be going back to OP and following other instructions? If I follow the above, should I then go back into OP and finish up anything else (i.e. new flash and nandroid backup)? I am not looking to install custom ROM yet, just wanting CWR to be there for recovery and backups and have it ready to play with ROM's as they get fleshed even more.
Have spent hours reading this thread, very informative and much thanks to all those experts helping us noobs. I hopefully put all the details you need to help provide an answer as I have seen one off general questions be asked without the details being provided...if you do need to know more though let me know.
Thanks again all!!
