- Jan 21, 2011
- 654
- 140
Your internal CWR is v3.0.0.5, and even though you used an ext4 bootable card, your internal recovery is still the older version. You should download the flashable CWRv3.0.1.0 - place it on your NC - reboot into recovery (which will be 3.0.0.5) and flash the zip, thus updating your internal recovery to v3.0.1.0.My Nook has Clockworkmod recovery 3.0.0.5 installed.
I want to install phiremod-nook-V5.1.zip
I am using a 2GB card and using 2gb_clockwork-0.1-ext4.img
I believe I'm doing everything correctly, I format the system/data/cache/dalvik cache, then I install the ROM from the SD card, it installs correctly, but when the Nook reboots I only have the Clockworkmod recovery 3.0.0.5 screen.
What am I doing wrong? Why don't I see the Phiremod 5.1 ROM???
Please help.
Thank you
Grab the flashable zip from here: http://www.androidtablets.net/forum...ry-official-cwm-3-0-1-0-update-flashable.html
Not exactly. If you want to keep your internal recovery as stock and continue to only use the SD for backups, you need to get the CWRv3.0.1.0 Bootable image and make a new SD card. You can move all your files off the existing card and back onto the new card after you burn the new image. Grab the properly sized image from here: http://www.androidtablets.net/forum...le-cwr-msd-v3-0-1-0-ext3-ext4-compatible.htmlI do not have CWR at all on my autonootered and overclocked 3.0.0 Nook. I use a bootable CWR SD card. Should I place the CWR 3.0.1.0 zip onto the SD card and then flash the eMMC that way?
If I do that, I shouldn't have to worry about flashing CWR via Rom manager, correct? Therefore, I shouldn't have to worry about the (old) vs regular issue?
thanks.
If you want to install CWRv3.0.1.0 to your internal recovery, the easiest way is to download ROM Manager from the market (should be v3.0.1.4 now), 'Flash ClockworkMod Recovery' from ROM Manager [MAKE SURE YOU POWER OFF AND POWER ON], then place the flashable CWRv3.0.1.0 on your NC or storage SD, Reboot into Recovery, and flash the zip to update CWR to latest. Grab the flashable CWR here: http://www.androidtablets.net/forum...ry-official-cwm-3-0-1-0-update-flashable.html
I THINK you need to do the following.
Grab the cwr 3.0.1.0 ZIP file and put it onto your 2gb SD card
Put the latest phirmod zip file rom on the same 2gb SD card.
Boot into your internal 3.0.0.5 CWR.
FLASH the 3.0.1.0 CWR zip.
unmount card
take out SD card
reboot.
Now you should see the correct version of CWR on your eMMC.
From there Flash the latest phiremod ROM.
I am not sure, but you might also need flash Gapps as well to get the market and such. you'll probably also want to flash the latest OC kernal for phiremod.
Pretty sure that poster didn't have an internal CWR so this wouldn't work.
Depends on the version of the bootable card used.Everything is correct, but keep in mind that whenever CWR comes from SD, old version will appear.
you mean it will appear to be an OLD version, but its not....its actually the newer version.
Question. Once I have 3.0.1.0 CWR installed to eMMC, sine it is both ext3 and ext4 compatible, I should have no trouble "restoring" my Nand backup of rooted 2.1 correct?
for instance, lets say I FLASH CM7 onto my eMMC after backuping up my stock rooted 2.1 ROM....In order to go back to my backup 2.1 ROM, i can simply go into rom manager and "restore" the ROM? should I wipe cache/dalvik cache prior to each restore? Should I wipe data/system?
And likewise, say i'm in my 2.1 image and I want to go back to my backed up CM7 ROM...i can just go to rom manager and "restore" my CM7 ROM??
Correct, once you have good v3.0.1.0 properly installed to internal - you can "restore" back and forth. However, I noticed that when I restored an ext3 based ROM and booted into recovery it showed my CWR as v3.0.0.5 even though it was really v3.0.1.0. When I restored back to CM7 my recovery showed as v3.0.1.0 as it should. So THIS is the instance CWR appears as the wrong version. Not sure why.
