Supergirl9801
- Mar 25, 2011
- 15
- 1
LMK if there's anything else with the info I gave you please. TYSVM!!Need more info:
-What rom are you running? ?? I haven't loaded anything special yet...I think maybe that's the step I missed?
-Are you running a rom from sd or internal?
-What is on the sd cards? Nothing but WMPInfo and netsetup.
-Is your CWM recovery installed on sd or internally? Internally
You possibly just messed up you boot files a bit. Have you tried turning the NC off then turning back on. Does it still boot into CWM recovery? Yes and Yes
If you messed up CWM recovery and can't boot to it
1) Create a bootable CWM SD card from the link above.
2) Mount the SD card on your computer and copy the RecoveryFix.zip file to it.
3) Boot the Nook into CWM from the SD card.
4) Choose "install zip from sdcard"
5) Choose "choose zip from sdcard"
6) Browse to the RecoveryFix.zip and select it.
7) Choose "Yes - Install RecoveryFix.zip"
CWM should now work by booting and holding the N + Power buttons.
You can find the recoveryfix file RecoveryFix.zip
If you still just boot into CWM recovery, just remove CWM recovery to restore the stock recovery I will try this step and update my post.
-Download the removecwr.zip file from HERE
-Put this zip file on your SD Card (DO NOT EXTRACT IT, JUST COPY THE ZIP TO THE ROOT OF YOUR SD CARD)
Another question about this step...am I just dragging this from my downloads file into my SD folder or do I have to put it into another sub folder of some sort...right now the only thing the folder has in it is WMPInfo and netsetup. These aren't folders though I'm noticing. BTW is this how I messed up my other SD card, by deleting those two things?? If so is there a way to get them back and fix my new SD card??
One other thing about this step....when do I use this zip file or does it just do something on it's own when the card is inserted?
-Turn off your NC
-Insert your SD card and restart the NC
-Once in CWR, use volume up and down buttons to scroll up and down the menu list
-Scroll down to "wipe cache partition"
-Press "n" button to enter or go to next sub-menu
-Scroll down to "yes - wipe cache"
-Press "n" button to execute
-Once complete, you will be back to main menu
When I complete this step it says "Cache wipe complete." But under that says E:Can't mount/cache/recovery/log and a couple other similar things...then it just powers down and reboots again.????
-Scroll down to "advanced"
-Scroll down to "Wipe Dalvik cache"
-Press "n" to go to next sub-menu
-Scroll down to "yes - wipe dalvik cache"
-Press "n" to execute
I did try advancing and doing these steps too and they seemed to work but then it wouldn't let me just press the power button to get back to the main menu...I had to hold the power button for several seconds to get it to turn off, I selected Reboot system now but it just powered off again.
-Once complete, press power button to go back to main menu
-Select reboot system now
You should now be rebooting normally into your NC and your system should still be completely rooted.
Then re-install CWM recovery and preform another backup.
Stopping a backup or restore mid stream is really not a big deal, I've done it a few times without issue. You issue may be with the sd cards, so knowing what was on the second sd card may be important in trouble shooting your issue.
Once you get sorted out you really need to do the backup again since you can't use the "restore:" feature if you restore files are on two different sd cards.
