I was attempting to follow the steps in the 1st post to create a backup. Followed every step. After the backup is finished, I go to "Reboot system now" and it goes right back in to CWR.
What should I do? I did it several times and then I took out the msd card and did Reboot system now again and it went right back to the CWR
Did a manual reboot by powering down and still back into cwr.
Thanks Rico - Ok so I just want to clarify. Were these the steps that I messed up?
manually Installation New ClockworkMod 3.0.1.0 version: http://muffinworld.net/android/nookc...mr_3.0.1.0.zip
-Place zip on root of sd card, install in CWM recovery 3.0.0.5 to update.
Does this mean to just download that zip and put it on the mSD and put it inside of the NC before I go to the next step in ROM Manager?
READ WHOLE POST BEFORE PROCEEDING! USE AT YOUR OWN RISK!
-Once in CWR, use volume up and down buttons to scroll up and down the menu list
-Scroll down to "wipe cache partition"
-Press "n" button to enter or go to next sub-menu
-Scroll down to "yes - wipe cache"
-Press "n" button to execute
-Once complete, you will be back to main menu
-Scroll down to "advanced"
-Scroll down to "Wipe Dalvik cache"
-Press "n" to go to next sub-menu
-Scroll down to "yes - wipe dalvik cache"
-Press "n" to execute
-Once complete, press power button to go back to main menu
note: Clearing both caches is important to properly flashing any theme, kernel or Rom
-Once both caches are wiped, proceed to flashing a new kernel
-Scroll down to "install zip from sdcard"
-Scroll down to "choose zip from sdcard"
-Scroll to the kenral zip file you wish to flash (install)
-Press "n" to execute (pick file)
-Scroll down to "yes - Install (file name).zip"
-Press "n" to execute, flash new kernel
-Scroll to "reboot system"
note: if your NC locks up, just hold power button to reboot or power button and "n" button together
to boot back into CWR.
-Now back in NC, open SetCPU
note: If touch sensitivity is somewhat unresponsive, simply press the power button to make your NC
go to sleep, then "n" to wake back up. Your super responsive touch should return back to normal.
The author of the new kernels said there is something a little off on his kernel scripts and this
is the solution for this temporary touch issue. Work for me.
-In main menu, move slider on maximum setting over to far right to set max step speed
-Check Set on boot
-For other power saving profiles see: http://www.androidtablets.net/forum/nook-color-
technical/5119-setcpu-settings-nookcolor.html
note: After a kernel flash, SetCPU will set max per the last kernel install, so if you installed a
kernel with a higher clock, you need to re-set the max level.
Done, now enjoy your new quicker snappy Nook Color.
Any questions, let me know.
Full System Restore from Backup Using ClockworkMod Recovery
-First make sure you have at least a half changed battery
-If your NC is on, open ROM manager and press "Reboot to recovery"
-If you NC is off, press and hold the power and "n" buttons together for 5-6 seconds then let go of the buttons
See illustrations above.
note: If CWR locks up, which it frequently does with this version of CWR, don't panic it's ok, just press and hold the power button until your NC turns off. Then press and hold both power and "n" button for 5-6 seconds to boot back into CWR.
-Once both caches are wiped, proceed to performing a full system restore
-Scroll down to "backup and restore"
-Scroll down to "restore"
-Scroll to the backup image (by date) you wish to flash (install/restore)
-Press "n" to execute (pick image)
-Scroll down to "yes - Restore"
note: A full restore will take anywhere from 10-15 minutes to complete.
Once booted, you should still be rooted, be on same b&n software you backed up to and have all your same settings, apps, widgets and themes restored.
Have any question, let us know and one of our knowledgeable Nook Color owners will help you out.
im so sorry but for the life of me i cannot download the zip file, i cant access the site due to the proxy settings i have, and have been banging my head against the wall to try and fix it but to no avail. is there a way you could direct download it??
any help is appreciated im trying to overclock it and cant until i do this update being as i have the 1.1 and rooted with the 3.0. Boot looped once and fixed it but desperately ready to overclock.
