Hi everyone, I just got my g tab and am trying to get the clockworkmod to work. It looks like it installed and it shows the recovery key thing when I hold the on and + buttons but I caqn't get it to go into the full mode. Still looks like it is trying to download when I start up as well. I have read these directions and followed all of them. Even watched a YouTube and did it right along with it. I have done this from both the SD card and internal. What am I doing wrong. Sorry to be such a nooby about all of this...just want to have all of the fun you guys are!!
Debbie
I've read about a thousand ways to flash a new rom and gotten as far as CWM working and backup current stuff. Afraid to do more as there are questions:
Objective 2:
Install a ROM
For this section I will use TnT G-Harmony v1.2. You can change the steps according to the ROM you decided to install. You can find a list of current ROMs here.
ANother website (Android tablets for dummies off of XDA forum) went into "branches" of adroid (1.1 and 1.2???) does it matter which rom goes with what branch? do branches matter? The link is to my ROMs thread. Not another website. + I even hosted all of the ROMs you will find in that thread.
1. Clean your MicroSD card or delete the update.zip in the internal storage from Objective 1.
there is no update.zip from step #1 that i can see either in es file exp or on my PC. I put one IN there when i did the CWM install but now it appears to be gone. can it be hidden? why is it not there. You need to do this by putting the SD card back into your PC. Or connect the tablet by USB again to delete the file from the internal storage.
2. Create a folder called ROMs on your internal storage. DONE
3. Copy the gharmony.zip/yourrom.zip to the ROMs folder you just created. (Do NOT unzip the file. CWR uses .zip files. If your file has an update.zip in the original zip file (ie. tnt lite 4.20has an update.zip inside of the gtab_tnt_lite_4.20, rename it toromname.zip or something for easy identification.)
I plan on using Vegan 5.1 as there seems to be conflicting stuff on other sites about branches (1.1, and 1.2 and different ROMs for different branches that this thread does no address. I THINK 5.1 will work with my branch (1.1) but am not sure. I am not sure 5.1 vegan has update.zip in the. I have no idea what theses "branchs" are that you talk about.
Here is where i stop and wait further information from the kind souls here. in any event thanks for getting me to a better recovery boot mode. I hope to get better at this
BTW you may want to mention that you need to move the backup off the SD internal only obvious to me after i wiped it out when i repartitioned 2048/0 (which i prob didnt need to do but read elsewhere that it was "required") What backup are you talking about? The CWM backup? And you do NOT need to repartition. Unless you do not follow the directions and mess something up. I have flashed dozens of times with almost 20 different ROMs and have never had to repartition.
I have an SD plugged in the slot if that helps
. . . I downloaded tnt lite 4.20. I copied the zipped file and put in in the ROM folder. I rebooted into clockworkmod and followed steps. I am stuck at step 11, subtask 3. When I select ROMS folder I don't see any tnt4.20 in there. Can someone please tell me what I am doing wrong. . . . .
This will probably sound like a stupid question, but how do you reboot the g tablet? I would like to do the market fix and I am just unsure how to do this step!
Thanks for any help!
Debbie
Ok, I hope there is an easy answer here. Got my hands on a Gtablet for the wife today(no really, it is for her!). It came with bootloader 1.1 and i upgraded to 3588. Then I installed Clockwork mod. It went like a charm. But then I followed Fuganater's how to on the first page. I formatted the micro sd card, created a folder and labelled it ROMS. Then I downloaded tnt lite 4.20. I copied the zipped file and put in in the ROM folder. I rebooted into clockworkmod and followed steps. I am stuck at step 11, subtask 3. When I select ROMS folder I don't see any tnt4.20 in there. Can someone please tell me what I am doing wrong.
This is the error msg I am getting;
Installing : SDCARD:update.zip
Finding update package...
Opening update package...
E: Can't open /sdcard/update.zip
(no such file or directory)
Installation aborted
Thanks to this great community I know I will be up in no time.
Suggested that you read section Instructions for those with clockworkmod .8 from this thread [ROM - 1.1] RETIRED - TNT LITE alternate 1.1-based GTAB firmware - [G-TABLET\ZPAD T2] - SlateDroid.com and download TNT Lite 4.4.0.
Good luck,
Dave
