That's exactly what I was trying to post- there's no way a 5.5mm OD coax plug will fit in the 2.3 (approx) socket found on the A500. It's always a good idea to do your own groundwork on specs posted on the internet.... I don't trust anything I read without doing my own fact finding. In this case a $0.99 ruler and a quick look at the PDF for the adapter would have saved someone $30.I bought the ELK-P1216 and it is WAY too big to fit into the tablet.
*sarcastically* Thanks a lot. Now I am out $30 on something I cant use!
According to this poster (xda-developers - View Single Post - Power adaptors) it's the same length cord as the adapter supplied with the A500 (he didn't say how he determined it was the same length though).Does anyone know if the Acer Travel Charger is longer? I was looking at it too, but couldn't find any info on the length.
Thus my question earlier. I'm sorry that you had to be a guinea pig. There is another guy on Ebay selling chargers with extenders that are supposed to be for the A500: AC Adapter Power Supply Charger Acer Iconia Tablet A500 - eBay (item 140546720527 end time Jun-08-11 06:52:15 PDT)I bought the ELK-P1216 and it is WAY too big to fit into the tablet.
Picked one up at Walmart on the way home from work...Someone posted over at xda (xda-developers - View Single Post - [Q] ebay car charger) that this $15 car charger from Walmart works for the A500:
Walmart.com: Car Cord Adapter with Polarity Switch: Automotive
Disclaimer- not tested by me!!
They had this home charger at Walmart too- same manufacturer, same model number- but it's under powered as compared to the factory A500 wall charger that can supply up to1500mA.Amazon.com: PowerLine 90304 1,300mA Variable Voltage Universal AC Adapter with Compatability Tips and USB Power Port: Electronics
This worked. One of the included tips fits the Iconia just fine. It's 1300mA and can be set to 12v. Cable is just slightly over 6 ft in length. cost is $17.63 USD on Amazon
I have been using it for a few days and is working fine.
I would be a little concerned using an underated charger/power supply on a tablet.
I guess I will be the guinea pig for that one and report back to you all. If it works, that would be great. I've asked them to verify that it works for the A500 (so I'll have a written declaration in case it doesn't fit), so once they verify I'm ordering.
