robdroid
- May 4, 2011
- 141
- 13
To dispel some misinformation....
It's NEVER OK to underpower a complex electronic device either by current or voltage.
An AC to DC adapter must be able to supply UP TO the rated capacity that the powered device might draw. In our case the factory AC adapter for the A500 is certified to supply up to 1500mA of current at 12v DC. Using an AC adapter that cannot supply the correct voltage at the maximum power (current) draw could damage your equipment and your power supply.
It's always OK to use an AC to DC adapter that can supply more current than your powered device can DRAW. Notice the word DRAW- yes, the powered device draws power from the adapter and will only take as much as it needs, so if you have a 2000ma power supply, it's not a problem as the A500 will only draw up to 1500mA max- it won't draw 2000ma. The adapter won't "push" more current to the device than it needs- EVER. Voltage is a different matter- that has to match the powered devices needs. Both over and under volting devices is dangerous. Higher than rated voltage can exceed component maximum tolerance and burn out individual components (I.C.'s, diodes, transistors, etc..) on the main circuit board. Undervolting could cause the device to try to draw more current than the circuit is designed to carry and could overheat and burn out components too.
The basics for sourcing the correct power supply:
1) Type of current must match, i.e.- DC for DC devices AC for AC devices
2) Polarity must match- no exceptions- tip + or tip -
2) Voltage should match
3) Current must be equal to or higher than device can draw- but NOT lower than specified by device manufacturer.
Some links to backup above info:
RadioShack Guide to Understanding Power Conversion: AC Adapters
Digidave.co.uk Support Helpdesk - Powered By Kayako eSupport v2.3.5
How to Match Up AC Power Adapters | eHow.com
