I've finally managed to make my own extension to the Acer A500 power adapter. Mine snapped in the tablet so every time I tried to charge it kept falling out. I read lots and lots forums and people kept on stating sizes that fitted. Those I purchased off ebay and they never fitted!! In the end I went in to Maplin here in the UK and measured the tip needed. The tip that fits is DC Power Plugs : DC Power Connectors : Maplin Electronics 1.1mm (inner) / 3.00mm (outer). Cost me £1.69. What I did was cut the broken tip off. Soldered on a 2.5mm power line socket (the female connection). Then got an old adapter and cut all the ends off. Soldered on a 2.5mm plug (to fit the other 2.5mm socket) and finally on the end I soldered on the 1.1mm/3.0mm tip. It all works perfectly and gives me plenty of length. It all cost me £5.27. The Acer warranty doesn't cover physical damage and a new charger would have cost around £30!!
