[ROM] Blue Water - Kyros MID 8027 - MPMAN 827 - Mediox MID8027
Thank you for your work, but i didnt wanted an update.zip with clockworkmod on it.
I cant install the rar with the bluewater-rom on clockworkmod (apparently it only works with zip.)
So is it possible to post a zip-file with bluewater-rom on it? Or does anyone know, how it has to installed on a mpman 827 with clockworkmod with the rar file from the first post?
For bluewater instalation use the first post file.
there's a post on the first page on how to install the bluewater
My tablet don't enter to updade mode to apply blue water.
If I press POWER + VOL+ appears FWDN mode and if I press POWER + VOL- appear Fastboot mode.
I can't start blue water.
have u tried uninstalling the clockwork recovery mode? and then apply blue water?
I need a clocworkmod backup with bluewater instaled to make restore to my tablet
Maybe its a solution
I have absolutely the same thing here. on my tablet posted instructions do not start ROM flashing from sd card. It simply goes to FWDN mode, says "waiting" and nothing happenning.
I tried to unrar rom, then zip it, rename as update.zip and flash through clockmod recovery... no luck.
Is there an alternative way of flashing this rom than pressing Power + volume up ????
@InsaneWolf please provide more info.
Is it possible for you guys to remove clockworkmod?
Yes, this is not a problem.
But I try before to install clockworkmod and same problem.
I have stock img file and I can flash my tablet any time.
Only problem is can't enter "MID UPDATE" mode.
I have also a MID8024 and this is working( home button and power)
But MP827 is have touch home button and not working.
