InsaneWolf
- Jan 3, 2012
- 39
- 7
- Thread starter
- #46
Yes, this is not a problem.
But I try before to install clockworkmod and same problem.
I have stock img file and I can flash my tablet any time.
Only problem is can't enter "MID UPDATE" mode.
I have also a MID8024 and this is working( home button and power)
But MP827 is have touch home button and not working.
Note: MP827 update mode is NOT with power + home but WITH power + volume up. If this really does not work, can you provide me
with the MP827's img file, then maybe I can cook something up.
Also beware, this rom is not for the 8024 device. Also try to remove clockwork from the 827 and then follow the procedure I gave on page one, if that does not work I will need the 827's stock img file you use.
